This is new and quite annoying, it happened in our small facility this weekend:
One of my assistant was preparing keys on his Mac using our only Flame license, of course, it was the only one running. On the Service Monitor, the Wiretap Server (or) the Wiretap Gateway is red and no matter what we do to restart, it remains red, so we had to restart the Mac and then it works, but on the Starting Menu where you choose the project, all projects are greyed out.
The solution was to create a new project and import manually everything, this happened on a Mac mini, and on an Impc Pro freshly installed.
So this happened two times in one weekend, on two projects, on two machines.
I tried :
But the the files I have to alter in /etc/exports auto_master are impossible to edit
Hello Chadiabo!
Have you tried to run the Service Monitor application and run the Errors / Warnings last day and see what error are reported? Also, make sure Full Disk Access is enabled for Flame and its services. This is very often the root of many problems on macOS when content cannot be seen.
