Saving Reference Images????
adamt
Message 1 of 8
adamt
This used to be easy in Smoke, but now i'm using Flame I cannot figure out how to save an image into the Reference Buffer.
The manual has plenty telling you how to view them, but i cannot see one mention of how to save them so you can view them!  I even tried looking in the keyboard shortcuts and theres plenty of viewing options and nothing for saving/creating!
Please - how can i save a reference image ???
adam
Flame 2020.3
Replies (7)
Message 2 of 8
Grant.Kay
Hi Adam,
As far as I was aware the reference grab function is mapped to CONTROL+G in the Flame keyboard shortcuts.
Once that is done, you should be able to use the compare functions to refer back to the reference.
Regards
Grant
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
Message 3 of 8
fred.warren
Hello Adam,
To add to what Grant said, you can also use:
  • CTRL-B to enable / disable the Compare buffer in a viewport
  • CTRL-SHIFT-G to add an image to the buffer instead of overwriting the current one.
  • Press the 5 key on your keyboard's keypad (not the one above the R and T keys) and then use the 4 and 6 keys to navigate your reference buffer.
Also, you should be able to use the same shortcut profile you were using with Smoke in Flame. All the shortcuts you know about should work.
fred
Frédéric Warren
User Experience Designer
Message 4 of 8
Grant.Kay
Yeah, What Fred said 🙂
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Many thanks!
Regards
Grant
Grant Kay
Message 5 of 8
adamt
thank you, both!
Flame 2020.3
Message 6 of 8
adamt
one more question on the same subject - why can't i grab an image to the buffer whilst i'm in the timeline?  Should i be able to?
seems the only time i can actually grab a reference image is either when i am in an effect editor page (such as Colour Correct) or if i double click a clip to open it up, which makes for a less than fluid process.
adam
Flame 2020.3
Message 7 of 8
fred.warren
Hello Adam,
The Player doesn't use the same Compare workflow as Batch or the modules. Having a single Compare workflow available everywhere is something that has been enter as a request on Flame Feedback ( FI-00106 ). You can add your vote to that entry if you want.
Please accept this as a solution if you feel your question has been answered.
fred
Frédéric Warren
Message 8 of 8
adamt
thanks Fred - vote has been added!
Flame 2020.3
