Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
recover license from auction bought HP z800
3 REPLIES 3
400 Views, 3 Replies
Hi Gang!
I just bought a Hp Z800 from a defunk post production house.
Maybe it was a stupid thing to buy but a good deal.
The Redhat doesn't boot properly and right now I can't get in via single user mode...
but what I was wondering was is there any way to recover the flame license?
and any other AutoDesk registered software from that machine?
thanks
Ian
Tags (3)
3 REPLIES 3
lustrecolorist
The boot disk should be EXT3 formatted, which will make it readable on another working Linux machine.  If you connect it, you might be able to navigate the filesystem as long as it's not corrupted.  If you take a look in /usr/local/flexlm/license/ there should be a DL_license.dat file inside.  You'll want to save that.  If you open it in a text editor, and see entries for flame, flare, etc that look like this...
PACKAGE flamepremium_x86_64_r discreet_l \
COMPONENTS="flamepremium_all_r_2017_1 flamepremium_all_r_2017 \
FEATURE flamepremium_x86_64_r discreet_l 2017.999 permanent 1 \
SUPERSEDE ISSUED=13-Oct-2016 SIGN2="1A9B 85AB AB2C ...."
...with the term "permanent", you have a permanent node-locked license, and should be able to re-install and run the versions included in the license as long as the hardware configuration hasn't changed significantly since it was issued (hardware changes usually require a new license).
If you see a license entry that looks like this...
SERVER [server hostname] DLHOST03=AAABBBCCCDDDEEEFFFGGGHHHIIIJJJKKKLLL
VENDOR discreet_l
USE_SERVER
...then the machine was licensed over a network and you are most likely out of luck, unless the license server was included with what you bought as well.
In addition to the previous intervention, you will not be able to reuse the licenses if the OS and applications are installed on a different system drive as the dlhostid (key used for licensing) of the workstation is going to be different in this case.
If you have any questions about how to transfer licenses to new workstations or to new owners, please contact our licensing department at me.licensing@autodesk.com.
Yann
Yann Laforest
Program Manager Data Analytics - Autodesk EMS
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
in reply to: lustrecolorist
Thanks !
Still trying to get the z800 up and running on windows.
Will try to access the drive with virtual machine. Will let you know how I it goes.
Ian
