Mocha Tracking Import
Message 1 of 10
i am in the process of switching from Nuke to Flame.
I am used to track a lot in Mocha and from importing Mocha Tracks to Nuke
is basically Copy&Paste and a few clicks.
In Nuke I get a the Tracking Data in a Corner Pin Node and got to the Reference Frame.
I can then Set the Current Frame to my Referance Frame and thats it.
In Flame however, i find myself importing my Tracking Data onto a Bicubic and then fiddling
quite a Bit in the "2-UP Mode" to get the Placement Right.
Is there a way to do this faster?
Thank you 🙂
-haneiter
Replies (9)
Message 2 of 10
Grant.Kay
How are you exporting the tracking data out of Mocha? Which settings are you using?
Are you loading the tracking data into the stabiliser or are you loading an action setup in Flame.
It should not be difficult but I just want to narrow down what you're doing.
Regards
Grant
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
Message 3 of 10
i am exporting as *.stabilizer Data and using Action to load the Tracking Data.
Lets say I have Packshot i need to retouch my Action has 2 Inputs the Orginal and the painted Version.
I select the painted input, set the surface to bilinear, switch to the vertices tab and enter the Stabilizer to load my tracking.
Best,
Hans
Message 4 of 10
joelosis
i did a flame/smoke mocha webinar a while back maybe this will help
https://vimeo.com/89152100
Message 5 of 10
joelosis
also have a play with the flame planar tracker its rad
Message 6 of 10
Grant.Kay
I got hold of the latest version of Mocha and did a few test with Flame.
In Mocha, I set up a shape to do my planar track.   Next I added in the insert and offset the corners to the positions covering the area for the 4-point track.
To export the data, I chose to EXPORT OFFSET TRACKING DATA as a Autodesk IFFFSE Stabilizer Data.
I went into Flame and set up my surfaces.  I changed the image surface to Bilinear and selected all 4 corners.
I went into the Stabilizer and loaded the tracking data.   It matches what I saw in Mocha.
When I exit the Stabilizer the corners of the Bilinear surface match what I offset in Mocha and no adjustments are needed.
This work seems to be solid and it also worked with EXPORT TRACKING DATA as a Autodesk IFFFSE Stabilizer data.
Please note that if your track was 100%, you can still adjust the corners further in Flame and the offsets will stick with the tracking data.
Hope this helps.
Regards
Grant
Grant Kay
Message 7 of 10
thank you for your time. I switch a lot between Nuke and Flame and have currently no acces to the flame.
Will test this as soon as I can.
I think the problem is that i seldomly have 4 Corners.
Let say I have som Beauty work to do.
In Nuke i woud go to Mocha, track the Face Copy&Paste to Nuke.
Now i draw shapes for things I want to ColorCorrect/Retouch tell my corner Pin please use the Frame
I drew my shapes on as a reference and the shapes are tracking correctly.
This works without setting anything in Mocha and with every shape.
In Flame i think there is no "set to reference frame" function.
Nuke has to Tabs in the Corner Pin "To" and "From" Values.
The 4 To Values hold the Mocha Tracking Date, if I want to set a Reference Frame I copy the Values from the "To" Tab to the "From" Tab, so at this Frame the Corner Pin does nothing and I have a Reference Frame.
Is there a similar Function in Flame?
Message 8 of 10
Grant.Kay
Are you able to post a video showing the steps you are doing because I don't think I am following your example.
Many thanks!
Regards
Grant
Grant Kay
Message 9 of 10
Help please,
I did all the steps in exporting tracking data in Mocha Pro and loading it in Autodesk Flame 2017 using 4 point bilinear stabilizer, but it's not working. i've watched and read all the tutorials that i can find but so far i can't get it to work.
I have successfully loaded the tracking data of mocha pro into flame. but when i scrub or press play it doesn't work or the footage seems not reading the data.
btw the what am i tracking is a phone screen,
Thank you
Message 10 of 10
Hi
I'm sorry to jump in.
Have you checked animation data in action after loaded Mocha tracking data?
I had a experience that once I imported tracking data and it seemed nothing there but I found that animation data was slipped somewhere for some reasons after I checked.
You might be able to check and find an animation data which maybe correctly imported but it's just slipped far from your current working duration in animation.
