Solved by Grant.Kay. Go to Solution.
Hi ayanazafeera,
As far as I am aware, I never created a Batch Tutorial for Matchbox because it is really easy to use in Batch.
I did the Action videos because of how Matchbox tools can be applied to maps, camera and how they access 3D information from Action. None of this is required for using Matchbox in Batch. You treat it like any other node.
For example, in the Batch Node bin, just look for the Matchbox node. Drag it out and it will launch the file browser. You choose your Matchbox tool and it will be applied to the node when you return to batch.
All that is is left is to do is to connect your inputs and go into the Matchbox node and start tweaking settings.
Does that answer your question or is there anything particular you are looking for?
Regards
Grant
Hi ayanazafeera,
I don't think that Matchbox would get it exactly the same but if you could post a screengrab of what you get with sapphire and what you get with matchbox, we might be able to suggest a few ideas.
Regards
Grant
Hi, I dont have sapphire anymore in the machine to give you an example I'm looking for. Basically I'm asking is there a way for glow in matchbox to read the matte input. Because now, when I plug in matchbox glow with a matte, the whole scene glows,not only the item with a matte.
Hi ayanazafeera,
The other people answering the thread are correct with the suggested methods.
The Sapphire Glow spark is doing multiple operations including the glow as well as comping with the matte all in one node.
I do believe it might be possible to do that if the matchbox was rewritten.
However in its current state, the Glow Matchbox is only doing a glow to the matte and front. You will need to use the other nodes such as COMP to perform the operations going into the node as well as going out. Depending on whether you want the glow under the matte or over the matte will determine how you connect the nodes in the Batch flow-graph.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Kind Regards
Grant
try to go to https://logik-matchbook.org. There are several other Glow MX shader available.
Have fun
./ivar
