We have a Storage XR6500 with Flamepremium 2015. Yesterday, I opened the application and did not see the mount path / mnt / StorageMedia / SmokeFlame / p7. It seems to be erased. Clears has never been deleted because if I enter the command sw_df shows me that information is there.
[Root @ Ccolor StorageMedia] # cd / mnt / StorageMedia /
[Root @ Ccolor StorageMedia] # ls
Ls: reading directory.: Input / output error
[Root @ Ccolor StorageMedia] # sw_df
Partition Free Total % use iFree iTotal% use
7 710981 4244122 83 N / A N / A N / A
Can someone tell me how to retrieve this info? Or how do I create the mount point again? Without affecting the information.
Thank you,
Eduard Buitrago
Solved by joelosis. Go to Solution.
i would guess its either a drive dying or the connection to the storage since its giving you the i/o error
maybe 'gedit etc/fstab ' to check that dev paths to mount points r in order
