Hey guys,
I have the WiretapSDK_2017.0.1 installed and working (I tested some of the provided examples).
Anyway, I was wondering (as I'm sure many people have done this) does anyone have some documentation or examples for how to create a project through the API please?
Any help appreciated.
Thank you,
Shaun.
Solved by mchesnay. Go to Solution.
Hi mchesnay,
Thanks for taking the time to reply. I'm having a read through that now.
If I figure out how to do it, I'll post the solution here - in the meantime though, if anyone else has already done this in python, feel free to post your code too 🙂
Shaun.
Sucks that there is a C++ example, but not a python example.
I'm not able to get the C++ one to run.
I tried compiling it so I could run it, but I just get this:
g++ createProject.C -o createProject
createProject.C:31:30: error: WireTapClientAPI.h: No such file or directory
createProject.C: In function ‘int main(int, char**)’:
createProject.C:55: error: ‘WireTapClient’ was not declared in this scope
createProject.C:55: error: expected ‘;’ before ‘wireTapClient’
createProject.C:56: error: ‘wireTapClient’ was not declared in this scope
createProject.C:63: error: ‘WireTapServerId’ was not declared in this scope
createProject.C:63: error: expected ‘;’ before ‘serverId’
createProject.C:64: error: ‘WireTapServerHandle’ was not declared in this scope
createProject.C:64: error: expected ‘;’ before ‘server’
createProject.C:68: error: ‘WireTapNodeHandle’ was not declared in this scope
createProject.C:68: error: expected ‘;’ before ‘parentNode’
createProject.C:69: error: expected ‘;’ before ‘projectNode’
createProject.C:75: error: ‘parentNode’ was not declared in this scope
createProject.C:75: error: ‘projectNode’ was not declared in this scope
createProject.C:92: error: ‘WireTapStr’ was not declared in this scope
createProject.C:92: error: expected ‘;’ before ‘metadata’
createProject.C:110: error: ‘projectNode’ was not declared in this scope
createProject.C:110: error: ‘metadata’ was not declared in this scope
I also tried creating a project node like this (didn't work):
wiretap_create_node -n /projects -d test
Unable to create node: Node is read only
Try this:
./wiretap_create_node -n /volumes/stonefs -d delete_moi
The project must be created under the storage node: this is where the cache will be stored.
But after the project is created, you will find it under the /projects node, like you expected.
./wiretap_print_tree Server: 'test-iMac' WireTap Version: 2018 Server Vendor: Autodesk Product: IFFFS Version: 2018 Printing WireTap Tree <node> (HOST) Node ID: / volumes <node> (VOLUMES) Node ID: /volumes stonefs <node> (VOLUME) Node ID: /volumes/stonefs projects <node> (PROJECTS) Node ID: /projects delete_moi <node> (PROJECT) Node ID: /projects/delete_moi
Note that the project is created using the default values. Use ./wiretap_set_metadata to define custom values.
To set the project bit depth to 10 (up from the 8-bit default):
<Project><Name>delete_moi</Name><Nickname></Nickname><Description></Description><CreationDate>04/11/17 14:04:24</CreationDate><SetupDir>delete_moi</SetupDir><Partition>stonefs</Partition><Version>2018.0</Version><FrameWidth>1920</FrameWidth><FrameHeight>1080</FrameHeight><FrameDepth>8-bit</FrameDepth><AspectRatio>1.77778</AspectRatio><FieldDominance>PROGRESSIVE</FieldDominance><ProxyWidth>960</ProxyWidth><ProxyWidthHint>0.500000</ProxyWidthHint><ProxyMinFrameSize>720</ProxyMinFrameSize><ProxyAbove8bits>false</ProxyAbove8bits><ProxyQuality>lanczos</ProxyQuality><ProxyRegenState>0</ProxyRegenState><ProxyDepthMode>SAME_AS_HIRES</ProxyDepthMode><ProxyDepth>8-bit</ProxyDepth><BatchShaderPath>/opt/Autodesk/presets/2018.0/matchbox/shaders/</BatchShaderPath><ActionLightOperatorPath>/opt/Autodesk/presets/2018.0/action/lightbox/</ActionLightOperatorPath><ActionShaderPath>/opt/Autodesk/presets/2018.0/matchbox/shaders/</ActionShaderPath><ProcessMode>1</ProcessMode><IntermediatesProfile>0</IntermediatesProfile><FrameRate>29.97 fps NDF</FrameRate></Project>
If you start Flame, your project now has the updated frame depth of 10-bit.
HTH,
Happy to help!
And your questions highlighted the fact that the project creation topics in the wiretap docs could be better. I'll try to fix it for the next update.
Hi again,
I've got one more query that I hope you don't mind helping me with please?
This is working great except for one thing. It's not letting me specify what cfg preset file I can use.
E.g I create a project, just like you specify, but it always puts the video preview at: VideoPreviewWindow 1920, 1080, 25000p
and at the top of the file, it says this:
This is a project template file for SMPTE-274M 1920x1080@24.000Hz progressive
I would like to using the template based on this one however: /opt/Autodesk/presets/2017.1.2/cfg/linux-x86_64/template/1920x1080@50i.cfg
The problem is that the project folder where that cfg resides isn't created until I open my newly created project, so I'm not sure how I can enforce a specific cfg upon creation (using the wiretap way you explained)..
Any ideas?
Shaun.
