Hey,
Just wondering if anyone had some advice they could pass down..
If I render a setup without hardware AA the render time is less than a minute. If I turn Hardware AA on, the render time will be 40 minutes.
Hardware AA wouldn't result in a performance hit in previous versions of Flame at all, regardless of how many samples were turned on.
Should this be happening? Is there a recommended configuration I should be following?
Thanks!
Solved by Ought-o-Desk. Go to Solution.
Fyi, this problem was fixed with a Graphics Driver update.
I updated it to the latest Nvidia driver (above what the DKU recommended) and now it works as expected.
