Flame projects clip shows checker boxes in one of the projects, we checked with other rest of the projects they seems good to work but particular projects having an issue. Source path have file in its same location but render part is missing . As we gone through app log and shell log once we found the same reason in both the logs, Below here is the logs
"Could not modify reference counts for frame ids list: Frame id not found" this is in shell logs
"[error] 1625617664 wireDeviceSWEngine.C:515 12/18/24:13:22:30.251 Could not modify reference counts: Frame id not found this is app logs".
system - Centos7.6
flame - 2023.3
Workstation - HPZ840
Kindly find the attached logs in zip file
I would recommend to open a ticket with our Support team ASAP.
