I have a Question!
Machine Information :
Software Autodesk Flame Premium Luster 2015 extension3 sp1
Hardware : HP Z800
Lustre grading after working
Render output DPX files, and Render option One Sequence .
When Import to File Final Cut Pro 7.0.3 ,after File timecode is to be wrong.
Render output DPX has last frame is 1 frame missing .
Please. let me answer
Thanks.
Is it really a timecode mistmatch issue or is it a duration issue?
My understanding is that there is one frame that Final Cut does not read from rendered sequence.
Are all frames available in FC or is there a frame missing?
If there is one frame missing, is it the last one?
If so, does this frame show up in P view in Lustre?
I would suggest to try the following:
- Create the a new grade and render the sequence. See if the issue persist.
- Add a dummy black frame at the end of the sequence and then render it. See if the duration in FC is ok and if the black frame shows up.
Please let me know,
Yann
It is timecode mismatching issue.
- Most of the file mismatching in Lustre export file.
- last one frame missing.
- Lustre render option field1(interlace mode 1) and show up.
In other ways, I try render test.
1. same way rendering in Lustre(ex: clip timecode 00:18:33:09) ,and Load FCP (ex: clip timecode 00:18:33:08)
2. Trouble clip is Last 1 frame render again in Lustre (Lustre render option same)
3. Load FCP add last 1 frame at the end of the sequence.
4. FCP is timecode matching(ex:00:18:33:08 sequence + 1frame, = 00:18:33:09).
5. fcp sequence render file into Lustre load.
6. Lustre render file and Fcp render file to compare , after same timecode & duration.
I don`t know reason.
Thanks for getting back to me.
It is pretty hard to figure out what the cause of the issue is without looking a project and files.
Are you entitled to Technical Support assistance?
If so, I would suggest to contact our Technical Support team so one of our engineers could have a look and assist you with the issue.
Yann
