Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Flame doesn't launch on the newest Mac Studio Ultra
4 REPLIES 4
Chadiabo
1588 Views, 4 Replies
Hello
It just a fresh install from Flame 2022 that refused to lunch after the project configuration, then uninstall and install a Flame 2023 that doesn't even launch after the installation, giving this kind of error.
Stone+Wire are in Red and so Wiretap Gateway
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 program.C:1027 05/05/22:13:21:21.864 Warning: Qt WebEngine seems to be initialized from a plugin. Please set Qt::AA_ShareOpenGLContexts using QCoreApplication::setAttribute before constructing QGuiApplication.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 pythonHook.C:152 05/05/22:13:21:22.705 [PYTHON HOOK] 'customUIAction' hook have been deprecated. Support for it is not guaranteed in the future. Current used in '/opt/Autodesk/presets/2023/shotgun/flame_hooks/sg_initialize.py'.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 pythonHook.C:152 05/05/22:13:21:22.705 [PYTHON HOOK] 'customUIAction' hook have been deprecated. Support for it is not guaranteed in the future. Current used in '/opt/Autodesk/presets/2023/shotgun/flame_hooks/python_console.py'.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 shellCmd.C:335 05/05/22:13:21:32.890 Command killed by signal 13
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[error] 189392384 swConfig.C:1395 05/05/22:13:21:32.897 Could not check permissions on '/Volumes/T9/FLAME/.mirror': No such file or directory
/opt/Autodesk/log//wiretapgateway.log: 518:[error] 73119232 rcAppContext.cpp:265 05/05/22:13:25:57.594 IO handler error: Interrupted system call
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[warn] 44570112 ifffsWiretapServer.C:178 05/05/22:13:26:58.575 Full disk access does not seem to be enabled for /opt/Autodesk/wiretap/current/ifffsWiretapServer
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:58.764 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:58.939 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.114 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.277 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.417 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.535 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.703 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.868 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.985 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.118 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.292 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.465 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.640 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.802 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.953 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.069 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.222 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.393 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.569 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.739 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.851 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.969 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.135 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.305 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.452 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.568 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.685 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.849 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.022 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.136 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.305 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.469 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.572 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.690 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.846 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.969 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:04.119 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
4 REPLIES 4
Chadiabo
in reply to: Chadiabo
solved
slabrie
Chadi, for future reference, please explain how you have fixed the issue.
Stéphane Labrie
Senior Product Owner
Flame Family
Chadiabo
in reply to: slabrie
Sorry I thought it was solved by modifying the checklist inside security and privacy, it worked for Flame 2023 but I wanna run Flame 2022, and here I have a new error
Local Wiretap "IFFFS" service not running
johnprice106
I had the same issue. I installed Ventura 13.5.2 (this was the older OS) and this allowed me to launch Flame. I was desperate to get something working and I know this worked before. Ideally I would have found the issue with Sonoma but alas time didn't allow. I hope this helps.
