Hello
It just a fresh install from Flame 2022 that refused to lunch after the project configuration, then uninstall and install a Flame 2023 that doesn't even launch after the installation, giving this kind of error.
Stone+Wire are in Red and so Wiretap Gateway
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 program.C:1027 05/05/22:13:21:21.864 Warning: Qt WebEngine seems to be initialized from a plugin. Please set Qt::AA_ShareOpenGLContexts using QCoreApplication::setAttribute before constructing QGuiApplication.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 pythonHook.C:152 05/05/22:13:21:22.705 [PYTHON HOOK] 'customUIAction' hook have been deprecated. Support for it is not guaranteed in the future. Current used in '/opt/Autodesk/presets/2023/shotgun/flame_hooks/sg_initialize.py'.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 pythonHook.C:152 05/05/22:13:21:22.705 [PYTHON HOOK] 'customUIAction' hook have been deprecated. Support for it is not guaranteed in the future. Current used in '/opt/Autodesk/presets/2023/shotgun/flame_hooks/python_console.py'.
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[warn] 189392384 shellCmd.C:335 05/05/22:13:21:32.890 Command killed by signal 13
/opt/Autodesk/log//flame2023_Chadis-Mac-Studio_app.log:[error] 189392384 swConfig.C:1395 05/05/22:13:21:32.897 Could not check permissions on '/Volumes/T9/FLAME/.mirror': No such file or directory
/opt/Autodesk/log//wiretapgateway.log: 518:[error] 73119232 rcAppContext.cpp:265 05/05/22:13:25:57.594 IO handler error: Interrupted system call
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[warn] 44570112 ifffsWiretapServer.C:178 05/05/22:13:26:58.575 Full disk access does not seem to be enabled for /opt/Autodesk/wiretap/current/ifffsWiretapServer
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:58.764 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:58.939 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.114 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.277 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.417 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.535 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.703 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.868 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:26:59.985 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.118 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.292 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.465 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.640 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.802 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:00.953 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.069 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.222 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.393 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.569 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.739 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.851 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:01.969 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.135 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.305 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.452 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.568 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.685 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:02.849 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.022 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.136 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.305 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.469 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.572 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.690 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.846 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:03.969 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
/opt/Autodesk/log//ifffsWiretapServer.session.log.3:[error] 44570112 swdb_rcapi_shared.C:148 05/05/22:13:27:04.119 Unable to connect to Stone+Wire Database server on host 'localhost' port 7261: Connection refused.
Solved by Chadiabo. Go to Solution.
Chadi, for future reference, please explain how you have fixed the issue.
Sorry I thought it was solved by modifying the checklist inside security and privacy, it worked for Flame 2023 but I wanna run Flame 2022, and here I have a new error
Local Wiretap "IFFFS" service not running
I had the same issue. I installed Ventura 13.5.2 (this was the older OS) and this allowed me to launch Flame. I was desperate to get something working and I know this worked before. Ideally I would have found the issue with Sonoma but alas time didn't allow. I hope this helps.
