Announcements
Ethernet ports not working after installing DKU
remy_b-f
Observer
remy_b-f
Observer
Observer
We just got a new computer at work to run flame 2020, and I installed centOs 7.4 and then the DKU 14.0.
After installing CentOS, the network card integrated to the motherboard works perfectly fine, but after installing the DKU, is does not work anymore. I have no cards listed in system settings.
While installating the DKU, I get a message saying that the config file was not found, and that I can proceed with a generic installation, which I do. After rebooting, everything is fine except for that card.
Is there anyway I can make it work again, or just install the DKU without installing the network driver?
The motherboard is a supermicro MBD-X10DAX-O.
Thank you!
jeffrey.ramirez
Hi remy_b-f,
- DKU is installed with generic config if the system is not in the Autodesk Certified Workstations in the Flame System Requirement page.
What is the output of 'ifconfig -a' from terminal?
or the
systemctl status network
You may need to edit the network script file manually from the terminal as root:
vim /etc/sysconfig/network-scripts/ifcfg-ethX (or enX)
X=replace with the actual device number. ex, en0, en1, eth0
with these info:
DEVICE=enX
BOOTPROTO=static
# change the HWADDR with the MAC address of the eth device (refer dmesg or ifconfig for the MAC adress)
HWADDR=XX:XX:XX:XX:XX:XX
# change the IP address with the real ip needed
IPADDR=192.168.1.55
NETMASK=255.255.255.0
NM_CONTROLLED=yes
ONBOOT=yes
This info should also be inside  /etc/sysconfig/network-scripts/ADSKtemplate_ifcfg-ethX
Once edited, you may need to 'ifup' the device:
cd /etc/sysconfig/network-scripts/
ifup ifcfg-enX
you may also need to restart the network service:
systemctl restart network
Hope that helps.
Jeff
e0555945
Thanks Jeff you are a life saver!
