Errors installing Autodesk Flame
Message 1 of 15
My name is Nico and I recently installed an education version of Flame 2018 on my Mac. I was interested in installing Smoke at the same time to get a side by side comparison but would crash upon trying to install. I read online I could make this work by uninstalling Flame, then installing Smoke, and re-installing Flame but after I finished installing smoke the installation failed. When I tried to reinstall Flame I fail the same way. I am referred to look for an error code within the installer log. Here is my log:
2017-03-09 14:09:59:262 : TStpInstPkgHandler::setup - started
2017-03-09 14:09:59:263 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:09:59:263 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:09:59:263 : Installer error stream: authinstalltool: reading command.
2017-03-09 14:09:59:263 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-09 14:09:59:264 : Sending marshaled authorization.
2017-03-09 14:09:59:264 : TStpInstPkgHandler::setup - install_volume = /
2017-03-09 14:09:59:264 : TStpInstPkgHandler::setup - write = 1
2017-03-09 14:09:59:268 : Installer error stream: authinstalltool: Not running with privileges. Invoking self-repair
2017-03-09 14:09:59:268 : Installer error stream: authinstalltool: Creating named pipe.
2017-03-09 14:09:59:296 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:09:59:296 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:09:59:297 : Installer error stream: authinstalltool: Self repairing
2017-03-09 14:09:59:300 : Installer error stream: authinstalltool: self-repair done.
2017-03-09 14:09:59:300 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-09 14:09:59:300 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-09 14:09:59:300 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-09 14:09:59:301 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/clmv4.2.1.pkg on target:/
2017-03-09 14:09:59:301 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/clmv4.2.1.pkg -target / -verboseR
2017-03-09 14:09:59:566 : process stdout:installer: Package name is clmv4.2.1
2017-03-09 14:09:59:567 : Installer output: installer: Package name is clmv4.2.1
2017-03-09 14:09:59:567 : process stdout:installer: Upgrading at base path /
2017-03-09 14:09:59:567 : Installer output: installer: Upgrading at base path /
2017-03-09 14:09:59:567 : process stdout:installer:PHASE:Preparing for installation…
2017-03-09 14:09:59:578 : process stdout:installer:PHASE:Preparing the disk…
2017-03-09 14:09:59:622 : process stdout:installer:PHASE:Preparing clmv4.2.1…
2017-03-09 14:09:59:634 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-09 14:09:59:636 : process stdout:installer:PHASE:Configuring the installation…
2017-03-09 14:09:59:644 : process stdout:installer:STATUS:
2017-03-09 14:09:59:665 : Installer Status:
2017-03-09 14:10:00:136 : process stdout:installer:%2.229250
2017-03-09 14:10:00:137 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:00:638 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:01:642 : process stdout:installer:%97.750000
2017-03-09 14:10:01:644 : process stdout:installer:STATUS:
2017-03-09 14:10:01:661 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-09 14:10:01:699 : process stdout:installer:STATUS:
2017-03-09 14:10:01:733 : Installer Status:
2017-03-09 14:10:01:733 : process stdout:installer:%100.000000
2017-03-09 14:10:01:733 : !!!!Done!!!!!!
2017-03-09 14:10:01:744 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-09 14:10:01:761 : process stdout:installer: The upgrade was successful.
2017-03-09 14:10:01:761 : Installer output: installer: The upgrade was successful.
2017-03-09 14:10:01:762 : Installer Status:
2017-03-09 14:10:01:762 : Exited
2017-03-09 14:10:01:763 : TStpInstPkgHandler::setup - Exit status 0
2017-03-09 14:10:01:763 : TStpInstPkgHandler::setup - Exit Complete
2017-03-09 14:10:01:799 : TStpInstPkgHandler::setup - started
2017-03-09 14:10:01:821 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:10:01:822 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:10:01:822 : Installer error stream: authinstalltool: reading command.
2017-03-09 14:10:01:822 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-09 14:10:01:823 : Sending marshaled authorization.
2017-03-09 14:10:01:823 : TStpInstPkgHandler::setup - install_volume = /
2017-03-09 14:10:01:823 : TStpInstPkgHandler::setup - write = 1
2017-03-09 14:10:01:827 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-09 14:10:01:827 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-09 14:10:01:827 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-09 14:10:01:827 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/AdSSO-v2.pkg on target:/
2017-03-09 14:10:01:828 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/AdSSO-v2.pkg -target / -verboseR
2017-03-09 14:10:02:115 : process stdout:installer: Package name is AdSSO-v2
2017-03-09 14:10:02:115 : Installer output: installer: Package name is AdSSO-v2
2017-03-09 14:10:02:115 : process stdout:installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-09 14:10:02:115 : Installer output: installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-09 14:10:02:117 : Exited
2017-03-09 14:10:02:117 : TStpInstPkgHandler::setup - Exit status 1
2017-03-09 14:10:02:118 : !!!! ListPage: ExceptionMessage(3):Installation failed on Exit
2017-03-09 14:10:02:137 : TStpInstPkgHandler::setup - started
2017-03-09 14:10:02:158 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:10:02:159 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:10:02:159 : Installer error stream: authinstalltool: reading command.
2017-03-09 14:10:02:159 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-09 14:10:02:159 : Sending marshaled authorization.
2017-03-09 14:10:02:160 : TStpInstPkgHandler::setup - install_volume = /
2017-03-09 14:10:02:160 : TStpInstPkgHandler::setup - write = 1
2017-03-09 14:10:02:163 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-09 14:10:02:164 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-09 14:10:02:164 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-09 14:10:02:164 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmapps12.pkg on target:/
2017-03-09 14:10:02:164 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmapps12.pkg -target / -verboseR
2017-03-09 14:10:02:442 : process stdout:installer: Package name is adlmapps12
2017-03-09 14:10:02:442 : Installer output: installer: Package name is adlmapps12
2017-03-09 14:10:02:442 : process stdout:installer: Upgrading at base path /
2017-03-09 14:10:02:442 : Installer output: installer: Upgrading at base path /
2017-03-09 14:10:02:442 : process stdout:installer:PHASE:Preparing for installation…
2017-03-09 14:10:02:449 : process stdout:installer:PHASE:Preparing the disk…
2017-03-09 14:10:02:493 : process stdout:installer:PHASE:Preparing adlmapps12…
2017-03-09 14:10:02:502 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-09 14:10:02:516 : process stdout:installer:PHASE:Configuring the installation…
2017-03-09 14:10:02:527 : process stdout:installer:STATUS:
2017-03-09 14:10:02:549 : Installer Status:
2017-03-09 14:10:03:008 : process stdout:installer:%93.621837
2017-03-09 14:10:03:010 : process stdout:installer:PHASE:Cleaning up…
2017-03-09 14:10:03:503 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:04:506 : process stdout:installer:%97.750000
2017-03-09 14:10:04:508 : process stdout:installer:STATUS:
2017-03-09 14:10:04:509 : Installer Status:
2017-03-09 14:10:04:509 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-09 14:10:04:510 : process stdout:installer:STATUS:
2017-03-09 14:10:04:511 : Installer Status:
2017-03-09 14:10:04:511 : process stdout:installer:%100.000000
2017-03-09 14:10:04:512 : !!!!Done!!!!!!
2017-03-09 14:10:04:513 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-09 14:10:04:514 : process stdout:installer: The upgrade was successful.
2017-03-09 14:10:04:514 : Installer output: installer: The upgrade was successful.
2017-03-09 14:10:04:515 : Exited
2017-03-09 14:10:04:515 : TStpInstPkgHandler::setup - Exit status 0
2017-03-09 14:10:04:515 : TStpInstPkgHandler::setup - Exit Complete
2017-03-09 14:10:04:522 : TStpInstPkgHandler::setup - started
2017-03-09 14:10:04:543 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:10:04:543 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:10:04:543 : Installer error stream: authinstalltool: reading command.
2017-03-09 14:10:04:543 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-09 14:10:04:544 : Sending marshaled authorization.
2017-03-09 14:10:04:544 : TStpInstPkgHandler::setup - install_volume = /
2017-03-09 14:10:04:544 : TStpInstPkgHandler::setup - write = 1
2017-03-09 14:10:04:548 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-09 14:10:04:548 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-09 14:10:04:548 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-09 14:10:04:549 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmframework12.pkg on target:/
2017-03-09 14:10:04:549 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmframework12.pkg -target / -verboseR
2017-03-09 14:10:04:819 : process stdout:installer: Package name is adlmframework12
2017-03-09 14:10:04:819 : Installer output: installer: Package name is adlmframework12
2017-03-09 14:10:04:820 : process stdout:installer: Upgrading at base path /
2017-03-09 14:10:04:820 : Installer output: installer: Upgrading at base path /
2017-03-09 14:10:04:820 : process stdout:installer:PHASE:Preparing for installation…
2017-03-09 14:10:04:842 : process stdout:installer:PHASE:Preparing the disk…
2017-03-09 14:10:04:893 : process stdout:installer:PHASE:Preparing adlmframework12…
2017-03-09 14:10:04:902 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-09 14:10:04:904 : process stdout:installer:PHASE:Configuring the installation…
2017-03-09 14:10:04:905 : process stdout:installer:STATUS:
2017-03-09 14:10:04:906 : Installer Status:
2017-03-09 14:10:05:405 : process stdout:installer:%34.625592
2017-03-09 14:10:05:407 : process stdout:installer:PHASE:Writing files…
2017-03-09 14:10:05:902 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:06:408 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:06:904 : process stdout:installer:%97.750000
2017-03-09 14:10:06:907 : process stdout:installer:STATUS:
2017-03-09 14:10:06:908 : Installer Status:
2017-03-09 14:10:06:908 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-09 14:10:06:910 : process stdout:installer:STATUS:
2017-03-09 14:10:06:911 : Installer Status:
2017-03-09 14:10:06:911 : process stdout:installer:%100.000000
2017-03-09 14:10:06:911 : !!!!Done!!!!!!
2017-03-09 14:10:06:912 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-09 14:10:06:913 : process stdout:installer: The upgrade was successful.
2017-03-09 14:10:06:913 : Installer output: installer: The upgrade was successful.
2017-03-09 14:10:06:914 : Exited
2017-03-09 14:10:06:914 : TStpInstPkgHandler::setup - Exit status 0
2017-03-09 14:10:06:914 : TStpInstPkgHandler::setup - Exit Complete
2017-03-09 14:10:06:920 : TStpInstPkgHandler::setup - started
2017-03-09 14:10:06:943 : Installer error stream: authinstalltool: beginning run
2017-03-09 14:10:06:943 : Installer error stream: authinstalltool: Checking self repair
2017-03-09 14:10:06:944 : Installer error stream:
2017-03-09 14:10:06:944 : Installer error stream: authinstalltool: reading command.
2017-03-09 14:10:06:944 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-09 14:10:06:945 : Sending marshaled authorization.
2017-03-09 14:10:06:945 : TStpInstPkgHandler::setup - install_volume = /
2017-03-09 14:10:06:945 : TStpInstPkgHandler::setup - write = 1
2017-03-09 14:10:06:949 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-09 14:10:06:949 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-09 14:10:06:949 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-09 14:10:06:949 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg on target:/
2017-03-09 14:10:06:950 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg -target / -verboseR
2017-03-09 14:10:07:224 : process stdout:installer: Package name is AdlmFlexnetClient
2017-03-09 14:10:07:224 : Installer output: installer: Package name is AdlmFlexnetClient
2017-03-09 14:10:07:224 : process stdout:installer: Upgrading at base path /
2017-03-09 14:10:07:224 : Installer output: installer: Upgrading at base path /
2017-03-09 14:10:07:224 : process stdout:installer:PHASE:Preparing for installation…
2017-03-09 14:10:07:229 : process stdout:installer:PHASE:Preparing the disk…
2017-03-09 14:10:07:279 : process stdout:installer:PHASE:Preparing AdlmFlexnetClient…
2017-03-09 14:10:07:286 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-09 14:10:07:288 : process stdout:installer:PHASE:Configuring the installation…
2017-03-09 14:10:07:289 : process stdout:installer:STATUS:
2017-03-09 14:10:07:290 : Installer Status:
2017-03-09 14:10:07:787 : process stdout:installer:%2.229250
2017-03-09 14:10:07:788 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:08:287 : process stdout:installer:PHASE:Validating packages…
2017-03-09 14:10:09:290 : process stdout:installer:%97.750000
2017-03-09 14:10:09:292 : process stdout:installer:STATUS:Running installer actions…
2017-03-09 14:10:09:293 : Installer Status: Running installer actions…
2017-03-09 14:10:09:294 : process stdout:installer:STATUS:
2017-03-09 14:10:09:296 : Installer Status:
2017-03-09 14:10:09:296 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-09 14:10:09:297 : process stdout:installer:STATUS:
2017-03-09 14:10:09:297 : process stdout:installer:%100.000000
2017-03-09 14:10:09:297 : !!!!Done!!!!!!
2017-03-09 14:10:09:299 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-09 14:10:09:300 : process stdout:installer: The upgrade was successful.
2017-03-09 14:10:09:300 : Installer output: installer: The upgrade was successful.
2017-03-09 14:10:09:300 : Installer Status:
2017-03-09 14:10:09:301 : Exited
2017-03-09 14:10:09:301 : TStpInstPkgHandler::setup - Exit status 0
2017-03-09 14:10:09:301 : TStpInstPkgHandler::setup - Exit Complete
2017-03-09 14:10:09:310 : Running post-install script: ../Resources/dist/MACOSX-autodesk.postinstall
2017-03-09 14:10:14:401 : Wiretap Server stopped successfully.
2017-03-09 14:10:14:401 : pre/pos install launch results:
I attempted to install it multiple times to no avail. Any help?
Replies (14)
Message 2 of 15
Beau_James
Greetings njohnson4,
This is an issue that we are currently working on.  We will post back as soon as we have a solution.
Message 3 of 15
Beau_James
Please see the following knowledge base article for the resolution to this issue.
https://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Issue:
When you run your MAC installer, you receive an error during the install that may reference AdSSO.pkg. If you accept this message and the install completes, the software does not function.
Causes:
MAC module Certificate mismatch in the installer
Solution:
Download and install the appropriate AdSSO.pkg file for your system and install it.
  1. Download an updated package and move to your MAC desktop
  2. Double-click the downloaded package to mount the installer
  3. Follow and accept the prompts to install
  4. Close the installer when complete
  5. Install the appropriate program or run the desired program if already installed
Thank you for your patience.
Message 4 of 15
Hey again,
I successfully installed the AdSSo-V2.pkg for the 2017 and newer products in order to install the educational Flame 2018 version but still am getting a installation failure. I was still hopeful however because if I had gotten the program installed I could have worked around it but Flame 2018 isn't even installing on my device. The installer is running, saying it's installing everything and then giving me a big red X and saying it failed. I tried multiple times to be sure, still no luck.
At the end of my logs, which I've copied below I am seeing an "executor doesn't exist" issue that I didn't notice before. Any ideas?
Thanks in advance.
Nico
Logs:
2017-03-12 13:18:11:252 : Component: Flame Educational Edition not scheduled and disabled because already installed
2017-03-12 13:18:11:254 : Component: Flame Educational Edition not scheduled and disabled because already installed
2017-03-12 13:22:11:172 : Component: Flame Educational Edition not scheduled and disabled because already installed
2017-03-12 13:22:15:819 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:15:848 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:15:848 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:15:848 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:15:848 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:15:849 : Sending marshaled authorization.
2017-03-12 13:22:15:849 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:15:849 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:15:854 : Installer error stream: authinstalltool: Not running with privileges. Invoking self-repair
2017-03-12 13:22:15:854 : Installer error stream: authinstalltool: Creating named pipe.
2017-03-12 13:22:15:885 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:15:885 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:15:885 : Installer error stream: authinstalltool: Self repairing
2017-03-12 13:22:15:890 : Installer error stream: authinstalltool: self-repair done.
2017-03-12 13:22:15:890 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:15:890 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:15:890 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:15:890 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/clmv4.2.1.pkg on target:/
2017-03-12 13:22:15:891 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/clmv4.2.1.pkg -target / -verboseR
2017-03-12 13:22:16:142 : process stdout:installer: Package name is clmv4.2.1
2017-03-12 13:22:16:142 : Installer output: installer: Package name is clmv4.2.1
2017-03-12 13:22:16:142 : process stdout:installer: Upgrading at base path /
2017-03-12 13:22:16:142 : Installer output: installer: Upgrading at base path /
2017-03-12 13:22:16:143 : process stdout:installer:PHASE:Preparing for installation…
2017-03-12 13:22:16:150 : process stdout:installer:PHASE:Preparing the disk…
2017-03-12 13:22:16:202 : process stdout:installer:PHASE:Preparing clmv4.2.1…
2017-03-12 13:22:16:211 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-12 13:22:16:219 : process stdout:installer:PHASE:Configuring the installation…
2017-03-12 13:22:16:235 : process stdout:installer:STATUS:
2017-03-12 13:22:16:252 : Installer Status:
2017-03-12 13:22:16:717 : process stdout:installer:%2.229250
2017-03-12 13:22:16:720 : process stdout:installer:PHASE:Validating packages…
2017-03-12 13:22:17:218 : process stdout:installer:%97.750000
2017-03-12 13:22:17:220 : process stdout:installer:STATUS:
2017-03-12 13:22:17:235 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-12 13:22:17:252 : process stdout:installer:STATUS:
2017-03-12 13:22:17:269 : Installer Status:
2017-03-12 13:22:17:269 : process stdout:installer:%100.000000
2017-03-12 13:22:17:269 : !!!!Done!!!!!!
2017-03-12 13:22:17:285 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-12 13:22:17:302 : process stdout:installer: The upgrade was successful.
2017-03-12 13:22:17:302 : Installer output: installer: The upgrade was successful.
2017-03-12 13:22:17:303 : Installer Status:
2017-03-12 13:22:17:303 : Exited
2017-03-12 13:22:17:303 : TStpInstPkgHandler::setup - Exit status 0
2017-03-12 13:22:17:304 : TStpInstPkgHandler::setup - Exit Complete
2017-03-12 13:22:17:544 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:17:568 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:17:568 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:17:569 : Installer error stream:
2017-03-12 13:22:17:569 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:17:569 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:17:570 : Sending marshaled authorization.
2017-03-12 13:22:17:570 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:17:570 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:17:575 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:17:575 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:17:575 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:17:576 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/AdSSO-v2.pkg on target:/
2017-03-12 13:22:17:576 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/AdSSO-v2.pkg -target / -verboseR
2017-03-12 13:22:17:864 : process stdout:installer: Package name is AdSSO-v2
2017-03-12 13:22:17:865 : Installer output: installer: Package name is AdSSO-v2
2017-03-12 13:22:17:865 : process stdout:installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-12 13:22:17:865 : Installer output: installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-12 13:22:17:867 : Exited
2017-03-12 13:22:17:867 : TStpInstPkgHandler::setup - Exit status 1
2017-03-12 13:22:17:868 : !!!! ListPage: ExceptionMessage(3):Installation failed on Exit
2017-03-12 13:22:18:060 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:18:085 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:18:085 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:18:085 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:18:085 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:18:086 : Sending marshaled authorization.
2017-03-12 13:22:18:086 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:18:086 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:18:091 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:18:091 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:18:091 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:18:091 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmapps12.pkg on target:/
2017-03-12 13:22:18:092 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmapps12.pkg -target / -verboseR
2017-03-12 13:22:18:358 : process stdout:installer: Package name is adlmapps12
2017-03-12 13:22:18:358 : Installer output: installer: Package name is adlmapps12
2017-03-12 13:22:18:358 : process stdout:installer: Upgrading at base path /
2017-03-12 13:22:18:358 : Installer output: installer: Upgrading at base path /
2017-03-12 13:22:18:358 : process stdout:installer:PHASE:Preparing for installation…
2017-03-12 13:22:18:365 : process stdout:installer:PHASE:Preparing the disk…
2017-03-12 13:22:18:417 : process stdout:installer:PHASE:Preparing adlmapps12…
2017-03-12 13:22:18:426 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-12 13:22:18:441 : process stdout:installer:PHASE:Configuring the installation…
2017-03-12 13:22:18:456 : process stdout:installer:STATUS:
2017-03-12 13:22:18:474 : Installer Status:
2017-03-12 13:22:18:931 : process stdout:installer:%93.996746
2017-03-12 13:22:18:932 : process stdout:installer:PHASE:Cleaning up…
2017-03-12 13:22:19:427 : process stdout:installer:PHASE:Validating packages…
2017-03-12 13:22:20:433 : process stdout:installer:%97.750000
2017-03-12 13:22:20:436 : process stdout:installer:STATUS:
2017-03-12 13:22:20:437 : Installer Status:
2017-03-12 13:22:20:437 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-12 13:22:20:438 : process stdout:installer:STATUS:
2017-03-12 13:22:20:439 : Installer Status:
2017-03-12 13:22:20:439 : process stdout:installer:%100.000000
2017-03-12 13:22:20:439 : !!!!Done!!!!!!
2017-03-12 13:22:20:440 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-12 13:22:20:441 : process stdout:installer: The upgrade was successful.
2017-03-12 13:22:20:441 : Installer output: installer: The upgrade was successful.
2017-03-12 13:22:20:442 : Exited
2017-03-12 13:22:20:442 : TStpInstPkgHandler::setup - Exit status 0
2017-03-12 13:22:20:442 : TStpInstPkgHandler::setup - Exit Complete
2017-03-12 13:22:20:625 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:20:647 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:20:648 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:20:648 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:20:648 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:20:649 : Sending marshaled authorization.
2017-03-12 13:22:20:649 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:20:649 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:20:654 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:20:654 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:20:654 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:20:654 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmframework12.pkg on target:/
2017-03-12 13:22:20:654 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmframework12.pkg -target / -verboseR
2017-03-12 13:22:20:939 : process stdout:installer: Package name is adlmframework12
2017-03-12 13:22:20:939 : Installer output: installer: Package name is adlmframework12
2017-03-12 13:22:20:939 : process stdout:installer: Upgrading at base path /
2017-03-12 13:22:20:939 : Installer output: installer: Upgrading at base path /
2017-03-12 13:22:20:939 : process stdout:installer:PHASE:Preparing for installation…
2017-03-12 13:22:20:962 : process stdout:installer:PHASE:Preparing the disk…
2017-03-12 13:22:21:007 : process stdout:installer:PHASE:Preparing adlmframework12…
2017-03-12 13:22:21:014 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-12 13:22:21:020 : process stdout:installer:PHASE:Configuring the installation…
2017-03-12 13:22:21:022 : process stdout:installer:STATUS:
2017-03-12 13:22:21:023 : Installer Status:
2017-03-12 13:22:21:518 : process stdout:installer:%31.730242
2017-03-12 13:22:21:521 : process stdout:installer:PHASE:Writing files…
2017-03-12 13:22:22:020 : process stdout:installer:%88.211761
2017-03-12 13:22:22:022 : process stdout:installer:PHASE:Writing package receipts…
2017-03-12 13:22:22:518 : process stdout:installer:PHASE:Validating packages…
2017-03-12 13:22:23:030 : process stdout:installer:%97.750000
2017-03-12 13:22:23:031 : process stdout:installer:STATUS:
2017-03-12 13:22:23:032 : Installer Status:
2017-03-12 13:22:23:032 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-12 13:22:23:034 : process stdout:installer:STATUS:
2017-03-12 13:22:23:035 : Installer Status:
2017-03-12 13:22:23:035 : process stdout:installer:%100.000000
2017-03-12 13:22:23:035 : !!!!Done!!!!!!
2017-03-12 13:22:23:036 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-12 13:22:23:037 : process stdout:installer: The upgrade was successful.
2017-03-12 13:22:23:037 : Installer output: installer: The upgrade was successful.
2017-03-12 13:22:23:038 : Exited
2017-03-12 13:22:23:038 : TStpInstPkgHandler::setup - Exit status 0
2017-03-12 13:22:23:038 : TStpInstPkgHandler::setup - Exit Complete
2017-03-12 13:22:23:221 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:23:245 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:23:245 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:23:245 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:23:246 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:23:246 : Sending marshaled authorization.
2017-03-12 13:22:23:246 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:23:246 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:23:251 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:23:251 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:23:251 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:23:252 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg on target:/
2017-03-12 13:22:23:252 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg -target / -verboseR
2017-03-12 13:22:23:535 : process stdout:installer: Package name is AdlmFlexnetClient
2017-03-12 13:22:23:535 : Installer output: installer: Package name is AdlmFlexnetClient
2017-03-12 13:22:23:535 : process stdout:installer: Upgrading at base path /
2017-03-12 13:22:23:535 : Installer output: installer: Upgrading at base path /
2017-03-12 13:22:23:535 : process stdout:installer:PHASE:Preparing for installation…
2017-03-12 13:22:23:542 : process stdout:installer:PHASE:Preparing the disk…
2017-03-12 13:22:23:591 : process stdout:installer:PHASE:Preparing AdlmFlexnetClient…
2017-03-12 13:22:23:600 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-12 13:22:23:601 : process stdout:installer:PHASE:Configuring the installation…
2017-03-12 13:22:23:604 : process stdout:installer:STATUS:
2017-03-12 13:22:23:607 : Installer Status:
2017-03-12 13:22:24:102 : process stdout:installer:%82.391884
2017-03-12 13:22:24:107 : process stdout:installer:PHASE:Running package scripts…
2017-03-12 13:22:24:602 : process stdout:installer:PHASE:Validating packages…
2017-03-12 13:22:25:607 : process stdout:installer:%97.750000
2017-03-12 13:22:25:609 : process stdout:installer:STATUS:Running installer actions…
2017-03-12 13:22:25:610 : Installer Status: Running installer actions…
2017-03-12 13:22:25:611 : process stdout:installer:STATUS:
2017-03-12 13:22:25:612 : Installer Status:
2017-03-12 13:22:25:612 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-12 13:22:25:613 : process stdout:installer:STATUS:
2017-03-12 13:22:25:614 : Installer Status:
2017-03-12 13:22:25:614 : process stdout:installer:%100.000000
2017-03-12 13:22:25:614 : !!!!Done!!!!!!
2017-03-12 13:22:25:615 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-12 13:22:25:617 : process stdout:installer: The upgrade was successful.
2017-03-12 13:22:25:617 : Installer output: installer: The upgrade was successful.
2017-03-12 13:22:25:618 : Exited
2017-03-12 13:22:25:618 : TStpInstPkgHandler::setup - Exit status 0
2017-03-12 13:22:25:618 : TStpInstPkgHandler::setup - Exit Complete
2017-03-12 13:22:25:810 : TStpInstPkgHandler::setup - started
2017-03-12 13:22:25:834 : Installer error stream: authinstalltool: beginning run
2017-03-12 13:22:25:834 : Installer error stream: authinstalltool: Checking self repair
2017-03-12 13:22:25:834 : Installer error stream: authinstalltool: reading command.
2017-03-12 13:22:25:835 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-12 13:22:25:835 : Sending marshaled authorization.
2017-03-12 13:22:25:835 : TStpInstPkgHandler::setup - install_volume = /
2017-03-12 13:22:25:835 : TStpInstPkgHandler::setup - write = 1
2017-03-12 13:22:25:842 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-12 13:22:25:842 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-12 13:22:25:842 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-12 13:22:25:843 : Installer error stream: authinstalltool: Installing Install Flame Educational Edition.app/Contents/Resources/dist/Installer-Flame-2018.0.0-436.x86_64.mpkg on target:/
2017-03-12 13:22:25:843 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Educational Edition.app/Contents/Resources/dist/Installer-Flame-2018.0.0-436.x86_64.mpkg -target / -verboseR
2017-03-12 13:22:26:155 : process stdout:installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-03-12 13:22:26:156 : Installer output: installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-03-12 13:22:26:156 : process stdout:installer: Upgrading at base path /
2017-03-12 13:22:26:156 : Installer output: installer: Upgrading at base path /
2017-03-12 13:22:26:156 : process stdout:installer:PHASE:Preparing for installation…
2017-03-12 13:22:26:170 : process stdout:installer:PHASE:Preparing the disk…
2017-03-12 13:22:26:221 : process stdout:installer:PHASE:Preparing Autodesk Flame 2018 For Mac OS X…
2017-03-12 13:22:26:230 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-12 13:22:26:232 : process stdout:installer:PHASE:Configuring the installation…
2017-03-12 13:22:26:233 : process stdout:installer:STATUS:
2017-03-12 13:22:26:235 : Installer Status:
2017-03-12 13:22:26:736 : process stdout:installer:%49.697486
2017-03-12 13:22:26:739 : process stdout:installer:PHASE:Running package scripts…
2017-03-12 13:22:27:235 : process stdout:installer:%50.986870
2017-03-12 13:22:27:237 : process stdout:installer:PHASE:Running package scripts…
2017-03-12 13:22:27:736 : process stdout:installer:%52.276141
2017-03-12 13:22:27:738 : process stdout:installer:PHASE:Running package scripts…
2017-03-12 13:22:28:234 : process stdout:installer:%57.885694
2017-03-12 13:22:28:237 : process stdout:installer:PHASE:Moving items into place…
2017-03-12 13:22:28:734 : process stdout:installer:PHASE:Validating packages…
2017-03-12 13:22:29:241 : process stdout:installer:%97.750000
2017-03-12 13:22:29:243 : process stdout:installer:STATUS:Running installer actions…
2017-03-12 13:22:29:244 : Installer Status: Running installer actions…
2017-03-12 13:22:29:245 : process stdout:installer:STATUS:
2017-03-12 13:22:29:246 : Installer Status:
2017-03-12 13:22:29:246 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-12 13:22:29:249 : process stdout:installer:STATUS:
2017-03-12 13:22:29:250 : Installer Status:
2017-03-12 13:22:29:250 : process stdout:installer:%100.000000
2017-03-12 13:22:29:250 : !!!!Done!!!!!!
2017-03-12 13:22:29:251 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-12 13:22:29:252 : process stdout:installer: The upgrade was successful.
2017-03-12 13:22:29:252 : Installer output: installer: The upgrade was successful.
2017-03-12 13:22:29:253 : Exited
2017-03-12 13:22:29:253 : TStpInstPkgHandler::setup - Exit status 0
2017-03-12 13:22:29:254 : TStpInstPkgHandler::setup - Exit Complete
2017-03-12 13:22:29:445 : Running post-install script: ../Resources/dist/MACOSX-autodesk.postinstall
2017-03-12 13:22:29:475 : Running post install script ../Resources/dist/MACOSX-autodesk.postinstall
ERROR: executor does not exist.
End of script
2017-03-12 13:22:29:475 : pre/pos install launch results:
End of script
Message 5 of 15
Beau_James
can you check in the applications folder and see if it is there even with the failure.
Message 6 of 15
In my autodesk folder in my applications I only have three folders: one called "Adlm" one called "Synergy" and one called "maya2017." Maya is obviously for Maya but no other folder or files exist.
Message 7 of 15
brookstomlinson
I am as well having the same problem with the educational version.  I tried on two machines, both running sierra (10.12.2, and 10.12.3). Neither one would install the application.  I look at the folder, and flame is not there.
I saw a post on what the ids should be (5522710 /usr/discreet,5522710 /opt/Autodesk). mine are below.
 /usr/discreet =  455187
 /opt/Autodesk = 4338937
For kicks I tried installing on a system with 10.11.3, and it had errors but did install into the folder.
My logs for the Mac OS 10.12.2 are attached.
Message 8 of 15
yann.laforest
Hi Brooks,
To be clear, the IDs of /usr/discreet and /opt/Autodesk should not be 5522710 per se but they should be identical.
What other Autodesk applications (and versions) are installed on your workstation?
Yann
Yann Laforest
Principal Data Scientist Autodesk AEC
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Message 9 of 15
brookstomlinson
I do not have any other Autodesk application on the workstation that I attached the log for.
Message 10 of 15
yann.laforest
Hi Brooks,
Apologies for the misunderstanding.
I understood the the /usr/discreet directory was existing on the station.
Is that correct?
Yann
Yann Laforest
10 rue Duke Street
Message 11 of 15
brookstomlinson
No worries,
yes, it is on the workstation (a laptop). when I did the terminal "ls -id /usr/discreet" and "ls -id /opt/Autodesk".  My numbers do not match.  I tried deleting the folder via terminal and starting again, but it still would not install.
Message 12 of 15
yann.laforest
Thanks Brooks,
We will need to log in to your system in order to understand what is going on exactly.
Please contact me at yann.laforest@autodesk.com when you will have room for this and we will schedule something.
Yann
Yann Laforest
10 rue Duke Street
Message 13 of 15
maniatistheo
How was this issue resolved?
Message 14 of 15
mh
I'm trying to install Flame 2018.3 educational version on macOS High Sierra 10.13.1 and it fails. I do not have any other Autodesk applications installed. I've attached a screenshot of the end of the Install.log file. I checked the Applications folder and the Autodesk folder is there. I can see the Flame alias but it's solid which and click on it does not do anything.
Any help is appreciated. Thank you.
Message 15 of 15
Hectorc21
Community Visitor
Community Visitor
Hello, Beau
So it did install into the applications folder but now it's giving a message that it cannot start Application cannot start, /opt/Autodesk and /usr/discreet
exist and do not point to the same location.
