Error occurred Installing Flame 2018 trial Mac
Message 1 of 15
Wondering if anyone can help. I've recently tried to install the Trial version of Flame 2018 MAC but every time it's coming up "Installation Failed" right at the end.
I previously had Flame 2017 training edition installed, which worked fine. I uninstalled it using the uninstaller provided, even tried deleting the folders mentioned here:
https://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
yet it still won't install. I opened the Installer.Log and the first line says
"Component: Flame Trial Edition not scheduled and disabled because  already installed"
but I don't have anything installed and have never had this version installed before.
I've looked through the other posts and the only advice was to install the AdSSO-v2.pkg, I tried both at different times to no avail.
I reckoned maybe there's something interfering on my Mac, so decided to test the Trial installer on my girlfriend's MacBook, which has never seen anything Autodesk. But I got the same issue...
Am I missing something obvious that I'm not doing? is flame 2018 Trial getting confused with the left overs of 2017 training edition?
I can still reinstall 2017 training edition successfully, which is fine. just I wanted to see what was new and try it out haha
Any insight would be greatly appreciated
below is the full Log:
2017-03-26 12:20:08:145 : Component: Flame Trial Edition not scheduled and disabled because  already installed
2017-03-26 12:20:08:147 : Component: Flame Trial Edition not scheduled and disabled because  already installed
2017-03-26 12:20:24:654 : Component: Flame Trial Edition not scheduled and disabled because  already installed
2017-03-26 12:20:30:049 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:30:068 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:30:068 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:30:068 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:30:068 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:30:069 : Sending marshaled authorization.
2017-03-26 12:20:30:069 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:30:069 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:30:071 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:30:071 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:30:071 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:30:072 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/clmv4.2.1.pkg on target:/
2017-03-26 12:20:30:072 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/clmv4.2.1.pkg -target / -verboseR
2017-03-26 12:20:30:333 : process stdout:installer: Package name is clmv4.2.1
2017-03-26 12:20:30:333 : Installer output: installer: Package name is clmv4.2.1
2017-03-26 12:20:30:333 : process stdout:installer: Upgrading at base path /
2017-03-26 12:20:30:333 : Installer output: installer: Upgrading at base path /
2017-03-26 12:20:30:333 : process stdout:installer:PHASE:Preparing for installation…
2017-03-26 12:20:30:339 : process stdout:installer:PHASE:Preparing the disk…
2017-03-26 12:20:30:361 : process stdout:installer:PHASE:Preparing clmv4.2.1…
2017-03-26 12:20:30:368 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-26 12:20:30:379 : process stdout:installer:PHASE:Configuring the installation…
2017-03-26 12:20:30:395 : process stdout:installer:STATUS:
2017-03-26 12:20:30:397 : Installer Status:
2017-03-26 12:20:30:873 : process stdout:installer:%2.229250
2017-03-26 12:20:30:874 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:31:373 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:32:376 : process stdout:installer:%97.750000
2017-03-26 12:20:32:381 : process stdout:installer:STATUS:
2017-03-26 12:20:32:398 : Installer Status:
2017-03-26 12:20:32:398 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-26 12:20:32:415 : process stdout:installer:STATUS:
2017-03-26 12:20:32:448 : Installer Status:
2017-03-26 12:20:32:449 : process stdout:installer:%100.000000
2017-03-26 12:20:32:449 : !!!!Done!!!!!!
2017-03-26 12:20:32:465 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-26 12:20:32:481 : process stdout:installer: The upgrade was successful.
2017-03-26 12:20:32:481 : Installer output: installer: The upgrade was successful.
2017-03-26 12:20:32:482 : Exited
2017-03-26 12:20:32:482 : TStpInstPkgHandler::setup - Exit status 0
2017-03-26 12:20:32:482 : TStpInstPkgHandler::setup - Exit Complete
2017-03-26 12:20:32:635 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:32:654 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:32:655 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:32:655 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:32:655 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:32:655 : Sending marshaled authorization.
2017-03-26 12:20:32:656 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:32:656 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:32:658 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:32:658 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:32:658 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:32:659 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/AdSSO-v2.pkg on target:/
2017-03-26 12:20:32:659 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/AdSSO-v2.pkg -target / -verboseR
2017-03-26 12:20:32:908 : process stdout:installer: Package name is AdSSO-v2
2017-03-26 12:20:32:908 : Installer output: installer: Package name is AdSSO-v2
2017-03-26 12:20:32:908 : process stdout:installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-26 12:20:32:909 : Installer output: installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2017-03-26 12:20:32:910 : Exited
2017-03-26 12:20:32:910 : TStpInstPkgHandler::setup - Exit status 1
2017-03-26 12:20:32:910 : !!!! ListPage: ExceptionMessage(3):Installation failed on Exit
2017-03-26 12:20:33:051 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:33:069 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:33:069 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:33:069 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:33:069 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:33:070 : Sending marshaled authorization.
2017-03-26 12:20:33:070 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:33:070 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:33:073 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:33:073 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:33:073 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:33:074 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/adlmapps12.pkg on target:/
2017-03-26 12:20:33:074 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/adlmapps12.pkg -target / -verboseR
2017-03-26 12:20:33:335 : process stdout:installer: Package name is adlmapps12
2017-03-26 12:20:33:335 : Installer output: installer: Package name is adlmapps12
2017-03-26 12:20:33:335 : process stdout:installer: Upgrading at base path /
2017-03-26 12:20:33:335 : Installer output: installer: Upgrading at base path /
2017-03-26 12:20:33:335 : process stdout:installer:PHASE:Preparing for installation…
2017-03-26 12:20:33:341 : process stdout:installer:PHASE:Preparing the disk…
2017-03-26 12:20:33:365 : process stdout:installer:PHASE:Preparing adlmapps12…
2017-03-26 12:20:33:371 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-26 12:20:33:382 : process stdout:installer:PHASE:Configuring the installation…
2017-03-26 12:20:33:399 : process stdout:installer:STATUS:
2017-03-26 12:20:33:416 : Installer Status:
2017-03-26 12:20:33:876 : process stdout:installer:%94.012624
2017-03-26 12:20:33:878 : process stdout:installer:PHASE:Cleaning up…
2017-03-26 12:20:34:374 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:35:378 : process stdout:installer:%97.750000
2017-03-26 12:20:35:383 : process stdout:installer:STATUS:
2017-03-26 12:20:35:396 : Installer Status:
2017-03-26 12:20:35:396 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-26 12:20:35:401 : process stdout:installer:STATUS:
2017-03-26 12:20:35:434 : Installer Status:
2017-03-26 12:20:35:434 : process stdout:installer:%100.000000
2017-03-26 12:20:35:434 : !!!!Done!!!!!!
2017-03-26 12:20:35:451 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-26 12:20:35:468 : process stdout:installer: The upgrade was successful.
2017-03-26 12:20:35:468 : Installer output: installer: The upgrade was successful.
2017-03-26 12:20:35:469 : Exited
2017-03-26 12:20:35:469 : TStpInstPkgHandler::setup - Exit status 0
2017-03-26 12:20:35:469 : TStpInstPkgHandler::setup - Exit Complete
2017-03-26 12:20:35:603 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:35:621 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:35:621 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:35:621 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:35:622 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:35:622 : Sending marshaled authorization.
2017-03-26 12:20:35:622 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:35:622 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:35:626 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:35:626 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:35:626 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:35:627 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/adlmframework12.pkg on target:/
2017-03-26 12:20:35:627 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/adlmframework12.pkg -target / -verboseR
2017-03-26 12:20:35:876 : process stdout:installer: Package name is adlmframework12
2017-03-26 12:20:35:876 : Installer output: installer: Package name is adlmframework12
2017-03-26 12:20:35:876 : process stdout:installer: Upgrading at base path /
2017-03-26 12:20:35:876 : Installer output: installer: Upgrading at base path /
2017-03-26 12:20:35:876 : process stdout:installer:PHASE:Preparing for installation…
2017-03-26 12:20:35:894 : process stdout:installer:PHASE:Preparing the disk…
2017-03-26 12:20:35:939 : process stdout:installer:PHASE:Preparing adlmframework12…
2017-03-26 12:20:35:946 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-26 12:20:35:950 : process stdout:installer:PHASE:Configuring the installation…
2017-03-26 12:20:35:951 : process stdout:installer:STATUS:
2017-03-26 12:20:35:968 : Installer Status:
2017-03-26 12:20:36:447 : process stdout:installer:%53.496011
2017-03-26 12:20:36:448 : process stdout:installer:PHASE:Removing old files…
2017-03-26 12:20:36:946 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:37:953 : process stdout:installer:%97.750000
2017-03-26 12:20:37:968 : process stdout:installer:STATUS:
2017-03-26 12:20:37:979 : Installer Status:
2017-03-26 12:20:37:979 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-26 12:20:37:986 : process stdout:installer:STATUS:
2017-03-26 12:20:38:019 : Installer Status:
2017-03-26 12:20:38:019 : process stdout:installer:%100.000000
2017-03-26 12:20:38:019 : !!!!Done!!!!!!
2017-03-26 12:20:38:036 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-26 12:20:38:053 : process stdout:installer: The upgrade was successful.
2017-03-26 12:20:38:053 : Installer output: installer: The upgrade was successful.
2017-03-26 12:20:38:054 : Exited
2017-03-26 12:20:38:054 : TStpInstPkgHandler::setup - Exit status 0
2017-03-26 12:20:38:054 : TStpInstPkgHandler::setup - Exit Complete
2017-03-26 12:20:38:190 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:38:207 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:38:207 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:38:207 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:38:207 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:38:208 : Sending marshaled authorization.
2017-03-26 12:20:38:208 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:38:208 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:38:212 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:38:212 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:38:212 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:38:213 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg on target:/
2017-03-26 12:20:38:213 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/adlmflexnetclient.pkg -target / -verboseR
2017-03-26 12:20:38:449 : process stdout:installer: Package name is AdlmFlexnetClient
2017-03-26 12:20:38:449 : Installer output: installer: Package name is AdlmFlexnetClient
2017-03-26 12:20:38:449 : process stdout:installer: Upgrading at base path /
2017-03-26 12:20:38:450 : Installer output: installer: Upgrading at base path /
2017-03-26 12:20:38:450 : process stdout:installer:PHASE:Preparing for installation…
2017-03-26 12:20:38:454 : process stdout:installer:PHASE:Preparing the disk…
2017-03-26 12:20:38:480 : process stdout:installer:PHASE:Preparing AdlmFlexnetClient…
2017-03-26 12:20:38:486 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-26 12:20:38:487 : process stdout:installer:PHASE:Configuring the installation…
2017-03-26 12:20:38:503 : process stdout:installer:STATUS:
2017-03-26 12:20:38:521 : Installer Status:
2017-03-26 12:20:38:986 : process stdout:installer:%94.246540
2017-03-26 12:20:38:988 : process stdout:installer:PHASE:Cleaning up…
2017-03-26 12:20:39:491 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:40:493 : process stdout:installer:%97.750000
2017-03-26 12:20:40:504 : process stdout:installer:STATUS:Running installer actions…
2017-03-26 12:20:40:521 : Installer Status: Running installer actions…
2017-03-26 12:20:40:521 : process stdout:installer:STATUS:
2017-03-26 12:20:40:538 : Installer Status:
2017-03-26 12:20:40:538 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-26 12:20:40:571 : process stdout:installer:STATUS:
2017-03-26 12:20:40:588 : Installer Status:
2017-03-26 12:20:40:588 : process stdout:installer:%100.000000
2017-03-26 12:20:40:588 : !!!!Done!!!!!!
2017-03-26 12:20:40:605 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-26 12:20:40:623 : process stdout:installer: The upgrade was successful.
2017-03-26 12:20:40:623 : Installer output: installer: The upgrade was successful.
2017-03-26 12:20:40:624 : Exited
2017-03-26 12:20:40:624 : TStpInstPkgHandler::setup - Exit status 0
2017-03-26 12:20:40:625 : TStpInstPkgHandler::setup - Exit Complete
2017-03-26 12:20:40:774 : TStpInstPkgHandler::setup - started
2017-03-26 12:20:40:794 : Installer error stream: authinstalltool: beginning run
2017-03-26 12:20:40:794 : Installer error stream: authinstalltool: Checking self repair
2017-03-26 12:20:40:794 : Installer error stream: authinstalltool: reading command.
2017-03-26 12:20:40:794 : TStpInstPkgHandler::setup - fpProcess Running - about to write
2017-03-26 12:20:40:794 : Sending marshaled authorization.
2017-03-26 12:20:40:795 : TStpInstPkgHandler::setup - install_volume = /
2017-03-26 12:20:40:795 : TStpInstPkgHandler::setup - write = 1
2017-03-26 12:20:40:797 : Installer error stream: authinstalltool: Should now have privileges.
2017-03-26 12:20:40:797 : Installer error stream: authinstalltool: Read a properly sized Command.
2017-03-26 12:20:40:797 : Installer error stream: authinstalltool: Authorizing right com.autodesk.apcw.path for command.
2017-03-26 12:20:40:798 : Installer error stream: authinstalltool: Installing Install Flame Trial Edition.app/Contents/Resources/dist/Installer-Flame-2018.0.0-436.x86_64.mpkg on target:/
2017-03-26 12:20:40:798 : Installer error stream: authinstalltool: performOperation: /usr/sbin/installer -pkg Install Flame Trial Edition.app/Contents/Resources/dist/Installer-Flame-2018.0.0-436.x86_64.mpkg -target / -verboseR
2017-03-26 12:20:41:128 : process stdout:installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-03-26 12:20:41:129 : Installer output: installer: Package name is Autodesk Flame 2018 For Mac OS X
2017-03-26 12:20:41:129 : process stdout:installer: Upgrading at base path /
2017-03-26 12:20:41:129 : Installer output: installer: Upgrading at base path /
2017-03-26 12:20:41:129 : process stdout:installer:PHASE:Preparing for installation…
2017-03-26 12:20:41:141 : process stdout:installer:PHASE:Preparing the disk…
2017-03-26 12:20:41:185 : process stdout:installer:PHASE:Preparing Autodesk Flame 2018 For Mac OS X…
2017-03-26 12:20:41:192 : process stdout:installer:PHASE:Waiting for other installations to complete…
2017-03-26 12:20:41:193 : process stdout:installer:PHASE:Configuring the installation…
2017-03-26 12:20:41:205 : process stdout:installer:STATUS:
2017-03-26 12:20:41:222 : Installer Status:
2017-03-26 12:20:41:695 : process stdout:installer:%49.737773
2017-03-26 12:20:41:696 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:42:193 : process stdout:installer:%51.022113
2017-03-26 12:20:42:194 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:42:692 : process stdout:installer:%52.309711
2017-03-26 12:20:42:693 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:43:197 : process stdout:installer:%53.610939
2017-03-26 12:20:43:205 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:43:694 : process stdout:installer:%54.688691
2017-03-26 12:20:43:706 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:44:193 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:44:692 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:45:197 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:45:693 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:46:192 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:46:697 : process stdout:installer:%83.041816
2017-03-26 12:20:46:709 : process stdout:installer:PHASE:Running package scripts…
2017-03-26 12:20:47:195 : process stdout:installer:PHASE:Validating packages…
2017-03-26 12:20:48:216 : process stdout:installer:%97.750000
2017-03-26 12:20:48:227 : process stdout:installer:STATUS:Running installer actions…
2017-03-26 12:20:48:245 : Installer Status: Running installer actions…
2017-03-26 12:20:48:245 : process stdout:installer:STATUS:
2017-03-26 12:20:48:277 : Installer Status:
2017-03-26 12:20:48:277 : process stdout:installer:PHASE:Finishing the Installation…
2017-03-26 12:20:48:295 : process stdout:installer:STATUS:
2017-03-26 12:20:48:327 : Installer Status:
2017-03-26 12:20:48:327 : process stdout:installer:%100.000000
2017-03-26 12:20:48:327 : !!!!Done!!!!!!
2017-03-26 12:20:48:345 : process stdout:installer:PHASE:The software was successfully installed.
2017-03-26 12:20:48:361 : process stdout:installer: The upgrade was successful.
2017-03-26 12:20:48:361 : Installer output: installer: The upgrade was successful.
2017-03-26 12:20:48:362 : Exited
2017-03-26 12:20:48:362 : TStpInstPkgHandler::setup - Exit status 0
2017-03-26 12:20:48:362 : TStpInstPkgHandler::setup - Exit Complete
2017-03-26 12:20:48:491 : Running post-install script: ../Resources/dist/MACOSX-autodesk.postinstall
2017-03-26 12:20:48:513 : Running post install script ../Resources/dist/MACOSX-autodesk.postinstall
ERROR: executor does not exist.
End of script
2017-03-26 12:20:48:513 : pre/pos install launch results:
End of script
Replies (14)
Message 2 of 15
yann.laforest
The problem does not seem to be related to the AdSSO-v2.pkg here.
In order to figure out what the cause of the issue is, can you please do the following:
In a terminal:
1. Type the "ls -id /usr/discreet" command and hit the Enter key
2. Type the "ls -id /opt/Autodesk" command and hit the Enter key
The IDs returned should be identical like in the example below:
5522710 /usr/discreet
5522710 /opt/Autodesk
If they are not, this will cause the installation to fail.
Out of curiosity, is there any other Autodesk application installed on this workstation?
If not and if the IDs are different, you can try to remove the /opt/Autodesk directory and then re-launch the install.
To do so (still in a Terminal)
1. Type "sudo -su" and hit the Enter key
2. Type the administrator password
--> You are now logged as administrator - super-user
3. Type "rm -Rf /opt/Autodesk" and hit the Enter key
4. Try to reinstall Flame Trial
Please let me know,
Yann
Yann Laforest
Program Manager Data Analytics - Autodesk EMS
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Message 3 of 15
maniatistheo
Im having a similar issue where I'm trying to install Flame 2018 for OS X. Install runs through perfectly but no actual application appears in my Autodesk folder. I downloaded the 2018.1 install and that runs better giving me an application but it quits immediately. Seems like a permission issue?
Message 4 of 15
mh
Hi Yann,
I cannot install Flame EDU version. I've narrowed it down to /opt/Autodesk has an incorrect ID and only "system" has read/write permission. Both Wheel (root) and Everyone has read only. If I try to change permissions using Get Info, or as root chmod in terminal, I receive an error that I do not have permission to do this. I cannot delete the /opt/Audtodesk folder as the local admin user or as root. I've searched online but cannot find a way to forcefully delete a folder where only "system" has read-write permission. Any help is appreciated.
MacBook-Pro-2:opt markholloway$ sudo rm -rf /opt/Autodesk/
Password:
rm: /opt/Autodesk/: Operation not permitted
Password:
sh-3.2# rm -Rf Autodesk
rm: Autodesk: Operation not permitted
Message 5 of 15
mh
Sorted it out. I temporarily disabled Software Integrity Protection (SIP) and was able to delete the Autodesk folder.
1. Reboot Mac and hold CMD+R for Recovery Mode
2. Select Utility > Terminal
3. Type "csrutil disable"
4. Type "reboot"
5. Mac boots as expected. Login, open terminal, and enter "sudo rm -rf /opt/Autodesk"
This resolved the issue. If following this please be sure to boot into recovery mode again and enter "csrutil enable" to re-enable SIP.
Message 6 of 15
I'm having this same issue. I tried your terminal commands but this is what I ended up with...a whole bunch of permission denied lines.
Last login: Thu Apr 19 13:33:29 on ttys000
Beths-iMac:~ bethsowell$ ls -id /usr/discreet
1075884 /usr/discreet
Beths-iMac:~ bethsowell$ ls -id /opt/Autodesk
1075884 /opt/Autodesk
Beths-iMac:~ bethsowell$ sudo -su
sudo: option requires an argument -- u
usage: sudo -h | -K | -k | -L | -V
usage: sudo -v [-AknS] [-g groupname|#gid] [-p prompt] [-u user name|#uid]
usage: sudo -l[l] [-AknS] [-g groupname|#gid] [-p prompt] [-U user name] [-u
            user name|#uid] [-g groupname|#gid] [command]
usage: sudo [-AbEHknPS] [-C fd] [-g groupname|#gid] [-p prompt] [-u user
            name|#uid] [-g groupname|#gid] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-C fd] [-g groupname|#gid] [-p prompt] [-u user
            name|#uid] file ...
Beths-iMac:~ bethsowell$ rm -Rf /opt/Autodesk
rm: /opt/Autodesk/.installDeps/com.autodesk.adlm.tools.x86_64.deps: Permission denied
rm: /opt/Autodesk/.installDeps/com.autodesk.utilities.pkguninstaller.x86_64.deps: Permission denied
rm: /opt/Autodesk/.installDeps: Permission denied
rm: /opt/Autodesk/.installResume: Permission denied
rm: /opt/Autodesk/backburner/Adapters/CmdjobAdapter: Permission denied
rm: /opt/Autodesk/backburner/Adapters/mio_3_adapter: Permission denied
rm: /opt/Autodesk/backburner/Adapters/UserCmdjobAdapter: Permission denied
rm: /opt/Autodesk/backburner/Adapters/Wire: Permission denied
rm: /opt/Autodesk/backburner/Adapters: Permission denied
rm: /opt/Autodesk/backburner/backburner: Permission denied
rm: /opt/Autodesk/backburner/backburner_manager: Permission denied
rm: /opt/Autodesk/backburner/backburner_server: Permission denied
rm: /opt/Autodesk/backburner/backburnerConfig: Permission denied
rm: /opt/Autodesk/backburner/backburnerManager: Permission denied
rm: /opt/Autodesk/backburner/backburnerServer: Permission denied
rm: /opt/Autodesk/backburner/cfg/backburner.server.ids: Permission denied
rm: /opt/Autodesk/backburner/cfg/README: Permission denied
rm: /opt/Autodesk/backburner/cfg/wiretap.cfg.sample: Permission denied
rm: /opt/Autodesk/backburner/cfg: Permission denied
rm: /opt/Autodesk/backburner/cmdjob: Permission denied
rm: /opt/Autodesk/backburner/documentation/Backburner_User_Guide.url: Permission denied
rm: /opt/Autodesk/backburner/documentation: Permission denied
rm: /opt/Autodesk/backburner/lan/ENG/nrres_ENG.dat: Permission denied
rm: /opt/Autodesk/backburner/lan/ENG: Permission denied
rm: /opt/Autodesk/backburner/lan: Permission denied
rm: /opt/Autodesk/backburner/Network/Archive: Permission denied
rm: /opt/Autodesk/backburner/Network/backburner.log: Permission denied
rm: /opt/Autodesk/backburner/Network/backburner.xml: Permission denied
rm: /opt/Autodesk/backburner/Network/backburner.xml.sample: Permission denied
rm: /opt/Autodesk/backburner/Network/backburnerServer.log: Permission denied
rm: /opt/Autodesk/backburner/Network/DropBox: Permission denied
rm: /opt/Autodesk/backburner/Network/Jobs: Permission denied
rm: /opt/Autodesk/backburner/Network/ServerJob: Permission denied
rm: /opt/Autodesk/backburner/Network/Servers/18D6C7611B342DAB.minfo: Permission denied
rm: /opt/Autodesk/backburner/Network/Servers/18D6C7611B342DAB.xml: Permission denied
rm: /opt/Autodesk/backburner/Network/Servers: Permission denied
rm: /opt/Autodesk/backburner/Network/Temp: Permission denied
rm: /opt/Autodesk/backburner/Network/Updates: Permission denied
rm: /opt/Autodesk/backburner/Network/wiretap.cfg: Permission denied
rm: /opt/Autodesk/backburner/Network/wiretap.res: Permission denied
rm: /opt/Autodesk/backburner/Network: Permission denied
rm: /opt/Autodesk/backburner/nrapi.conf: Permission denied
rm: /opt/Autodesk/backburner/nrapi.conf.sample: Permission denied
rm: /opt/Autodesk/backburner/WaitForNetwork: Permission denied
rm: /opt/Autodesk/backburner/WebMonitor/backburner.auth: Permission denied
rm: /opt/Autodesk/backburner/WebMonitor/flashmonitor_httpd_conf: Permission denied
rm: /opt/Autodesk/backburner/WebMonitor: Permission denied
rm: /opt/Autodesk/backburner: Permission denied
rm: /opt/Autodesk/cfg/.current: Permission denied
rm: /opt/Autodesk/cfg/channelrules.cfg: Permission denied
rm: /opt/Autodesk/cfg/channelrules.cfg.sample: Permission denied
rm: /opt/Autodesk/cfg/legacy.res.cfg: Permission denied
rm: /opt/Autodesk/cfg/network.cfg: Permission denied
rm: /opt/Autodesk/cfg/network.cfg.sample: Permission denied
rm: /opt/Autodesk/cfg/pathTranslation.cfg: Permission denied
rm: /opt/Autodesk/cfg/pathTranslation.cfg.sample: Permission denied
rm: /opt/Autodesk/cfg/umask.cfg: Permission denied
rm: /opt/Autodesk/cfg/umask.cfg.sample: Permission denied
rm: /opt/Autodesk/cfg: Permission denied
rm: /opt/Autodesk/clip: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Info.plist: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/MacOS/ServiceMonitor: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/MacOS: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/executor: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/metadaemon: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/monitorcfg.xml: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/running.png: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/stopped.png: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/SystemsMonitor.icns: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources/unknown.png: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents/Resources: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app/Contents: Permission denied
rm: /opt/Autodesk/Common Utilities/Service Monitor.app: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Info.plist: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/MacOS/Uninstaller: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/MacOS: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources/autodesk_uninstaller_background.png: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources/en.lproj/Introduction.rtf: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources/en.lproj/MainMenu.nib: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources/en.lproj/Summary.rtf: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources/en.lproj: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents/Resources: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app/Contents: Permission denied
rm: /opt/Autodesk/Common Utilities/Uninstaller.app: Permission denied
rm: /opt/Autodesk/Common Utilities/vxfCheckOS: Permission denied
rm: /opt/Autodesk/Common Utilities: Permission denied
rm: /opt/Autodesk/flame_2019/cfg/init.cfg: Permission denied
rm: /opt/Autodesk/flame_2019/cfg/init.cfg.original: Permission denied
rm: /opt/Autodesk/flame_2019/cfg: Directory not empty
rm: /opt/Autodesk/flame_2019: Permission denied
rm: /opt/Autodesk/font: Permission denied
rm: /opt/Autodesk/io/previous: Permission denied
rm: /opt/Autodesk/io: Permission denied
rm: /opt/Autodesk/lib64/backburner/2018.0/libDLnrapi.dylib: Permission denied
rm: /opt/Autodesk/lib64/backburner/2018.0: Permission denied
rm: /opt/Autodesk/lib64/backburner: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg/17733/libavcodec.52.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg/17733/libavdevice.52.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg/17733/libavformat.52.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg/17733/libavutil.49.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg/17733: Permission denied
rm: /opt/Autodesk/lib64/codecs/FFmpeg: Permission denied
rm: /opt/Autodesk/lib64/codecs/LAME/2007.10.01/libmp3lame.0.0.0.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/LAME/2007.10.01/libmp3lame.0.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/LAME/2007.10.01/libmp3lame.dylib: Permission denied
rm: /opt/Autodesk/lib64/codecs/LAME/2007.10.01: Permission denied
rm: /opt/Autodesk/lib64/codecs/LAME: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11/framework/mc_dec_mp2v.framework/mc_dec_mp2v: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11/framework/mc_dec_mp2v.framework: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11/framework/mc_enc_mp2v.framework/mc_enc_mp2v: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11/framework/mc_enc_mp2v.framework: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11/framework: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2/9.11: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept/mpeg2: Permission denied
rm: /opt/Autodesk/lib64/codecs/MainConcept: Permission denied
rm: /opt/Autodesk/lib64/codecs: Permission denied
rm: /opt/Autodesk/lib64/DLmpd: Permission denied
rm: /opt/Autodesk/lib64/DLmpd_Admin.dylib: Permission denied
rm: /opt/Autodesk/lib64/DLmpd_Sys.dylib: Permission denied
rm: /opt/Autodesk/lib64/DLmpd_Volume.dylib: Permission denied
rm: /opt/Autodesk/lib64/DLmpdctl: Permission denied
rm: /opt/Autodesk/lib64/libcsf.dylib: Permission denied
rm: /opt/Autodesk/lib64/libcsf_Admin.dylib: Permission denied
rm: /opt/Autodesk/lib64/libcsf_Sys.dylib: Permission denied
rm: /opt/Autodesk/lib64/libcsf_Volume.dylib: Permission denied
rm: /opt/Autodesk/lib64/pkguninstaller: Permission denied
rm: /opt/Autodesk/lib64: Permission denied
rm: /opt/Autodesk/log: Permission denied
rm: /opt/Autodesk/Lustre_Color/bin/calibrator_remote: Permission denied
rm: /opt/Autodesk/Lustre_Color/bin: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_ConstLclip_smoothed.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_CUSPclip_smoothed.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log/LC3DL_cg2log_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/cg_lin2log: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3510_log2sRGB_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3510_log2sRGB_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3510_log2sRGB_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3513_log2sRGB_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3513_log2sRGB_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Fuji3513_log2sRGB_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2383_log2sRGB_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2383_log2sRGB_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2383_log2sRGB_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2393_log2sRGB_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2393_log2sRGB_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB/LC3DL_Kodak2393_log2sRGB_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2sRGB: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3510_log2hd_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3510_log2hd_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3510_log2hd_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3513_log2hd_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3513_log2hd_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Fuji3513_log2hd_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2383_log2hd_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2383_log2hd_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2383_log2hd_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2393_log2hd_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2393_log2hd_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD/LC3DL_Kodak2393_log2hd_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/log2videoHD: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/DCI_rgb2xyz/LC3DL_Fuji3510_DCI_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/DCI_rgb2xyz/LC3DL_Fuji3513_DCI_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/DCI_rgb2xyz/LC3DL_Kodak2383_DCI_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/DCI_rgb2xyz/LC3DL_Kodak2393_DCI_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/DCI_rgb2xyz: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/JVC_HD2K_rgb2xyz/LC3DL_Fuji3510_JVC_HD2K_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/JVC_HD2K_rgb2xyz/LC3DL_Fuji3513_JVC_HD2K_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/JVC_HD2K_rgb2xyz/LC3DL_Kodak2383_JVC_HD2K_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/JVC_HD2K_rgb2xyz/LC3DL_Kodak2393_JVC_HD2K_XYZ.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz/JVC_HD2K_rgb2xyz: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/rgb2xyz: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/videoHD2log/LC3DL_hd2log_ConstLclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/videoHD2log/LC3DL_hd2log_ConstLmap.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/videoHD2log/LC3DL_hd2log_CUSPclip.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/videoHD2log/LC3DL_hd2log_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion/videoHD2log: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/conversion: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_240W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_240W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_240W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_240W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_240W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_240W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_240W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_240W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_240W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_240W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_240W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_240W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_240W_LCD: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG241W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG241W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG241W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG241W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG241W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG241W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG241W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG241W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG241W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG241W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG241W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG241W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG241W_LCD: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG245W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG245W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3510/LC3DL_Fuji3510_Eizo_CG245W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG245W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG245W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3513/LC3DL_Fuji3513_Eizo_CG245W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG245W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG245W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2383/LC3DL_Kodak2383_Eizo_CG245W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG245W.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG245W_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2393/LC3DL_Kodak2393_Eizo_CG245W_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Eizo_CG245W_LCD: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3510/LC3DL_Fuji3510_DCI.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3510/LC3DL_Fuji3510_DCI_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3513/LC3DL_Fuji3513_DCI.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3513/LC3DL_Fuji3513_DCI_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2383/LC3DL_Kodak2383_DCI.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2383/LC3DL_Kodak2383_DCI_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2393/LC3DL_Kodak2393_DCI.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2393/LC3DL_Kodak2393_DCI_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/XYZ_Preview/LC3DL_XYZ2RGB_preview.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector/XYZ_Preview: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_DCI_Projector: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3510/LC3DL_Fuji3510_HD_broadcast.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3510/LC3DL_Fuji3510_HD_broadcast_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3513/LC3DL_Fuji3513_HD_broadcast.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3513/LC3DL_Fuji3513_HD_broadcast_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2383/LC3DL_Kodak2383_HD_broadcast.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2383/LC3DL_Kodak2383_HD_broadcast_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2393/LC3DL_Kodak2393_HD_broadcast.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2393/LC3DL_Kodak2393_HD_broadcast_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/XYZ_Preview/LC3DL_XYZ2ITURGB_preview.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast/XYZ_Preview: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_ITU_709_HD_Broadcast: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3510/LC3DL_Fuji3510_sRGB.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3510/LC3DL_Fuji3510_sRGB_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3513/LC3DL_Fuji3513_sRGB.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3513/LC3DL_Fuji3513_sRGB_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2383/LC3DL_Kodak2383_sRGB.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2383/LC3DL_Kodak2383_sRGB_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2393/LC3DL_Kodak2393_sRGB.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2393/LC3DL_Kodak2393_sRGB_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Generic_sRGB: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3510/LC3DL_Fuji3510_JVC_HD2K.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3510/LC3DL_Fuji3510_JVC_HD2K_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3513/LC3DL_Fuji3513_JVC_HD2K.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3513/LC3DL_Fuji3513_JVC_HD2K_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2383/LC3DL_Kodak2383_JVC_HD2K.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2383/LC3DL_Kodak2383_JVC_HD2K_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2393/LC3DL_Kodak2393_JVC_HD2K.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2393/LC3DL_Kodak2393_JVC_HD2K_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/JVC_HD2K_Projector: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3510/LC3DL_Fuji3510_Sony_GDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3510/LC3DL_Fuji3510_Sony_GDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3513/LC3DL_Fuji3513_Sony_GDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3513/LC3DL_Fuji3513_Sony_GDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2383/LC3DL_Kodak2383_Sony_GDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2383/LC3DL_Kodak2383_Sony_GDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2393/LC3DL_Kodak2393_Sony_GDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2393/LC3DL_Kodak2393_Sony_GDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_GDM_900_CRT: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3510/LC3DL_Fuji3510_Sony_SDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3510/LC3DL_Fuji3510_Sony_SDM_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3510/LC3DL_Fuji3510_Sony_SDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3510: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3513/LC3DL_Fuji3513_Sony_SDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3513/LC3DL_Fuji3513_Sony_SDM_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3513/LC3DL_Fuji3513_Sony_SDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Fuji3513: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2383/LC3DL_Kodak2383_Sony_SDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2383/LC3DL_Kodak2383_Sony_SDM_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2383/LC3DL_Kodak2383_Sony_SDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2383: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2393/LC3DL_Kodak2393_Sony_SDM.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2393/LC3DL_Kodak2393_Sony_SDM_DCI_match.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2393/LC3DL_Kodak2393_Sony_SDM_gamut.3dl: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD/Kodak2393: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display/Sony_SDM_P234_LCD: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs/display: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut/Lustre_Color_3DLUTs: Permission denied
rm: /opt/Autodesk/Lustre_Color/lut: Permission denied
rm: /opt/Autodesk/Lustre_Color: Permission denied
rm: /opt/Autodesk/mio/previous: Permission denied
rm: /opt/Autodesk/mio: Permission denied
rm: /opt/Autodesk/openclip/previous: Permission denied
rm: /opt/Autodesk/openclip: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Negative.filter: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Negative.filter.p: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Negative.filter_node: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_1.filter: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_1.filter.p: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_1.filter_node: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_2.filter: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_2.filter.p: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Newsprint_2.filter_node: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Outline.filter: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets/Outline.filter.p: Permission denied
rm: /opt/Autodesk/presets/2017/filter/presets: Permission denied
rm: /opt/Autodesk/presets/2017/filter: Permission denied
rm: /opt/Autodesk/presets/2017: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Desaturate.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Desaturate.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss_heavy_soft.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss_heavy_soft.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss_soft.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Emboss_soft.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_cross_weave.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_cross_weave.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_heavy.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_heavy.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_heavy_soft.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fabric_heavy_soft.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fragment.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Fragment.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Halo.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Halo.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Jaggies.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Jaggies.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Negative.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Negative.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Newsprint_1.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Newsprint_1.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Newsprint_2.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Newsprint_2.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Outline.filter: Permission denied
rm: /opt/Autodesk/presets/2018/filter/Outline.filter.p: Permission denied
rm: /opt/Autodesk/presets/2018/filter: Permission denied
rm: /opt/Autodesk/presets/2018: Permission denied
rm: /opt/Autodesk/presets/2019/lut/Lustre_Color_3DLUTs: Permission denied
rm: /opt/Autodesk/presets/2019/lut: Permission denied
rm: /opt/Autodesk/presets/2019: Permission denied
rm: /opt/Autodesk/presets: Permission denied
rm: /opt/Autodesk/shared/export/presets/audio_file: Permission denied
rm: /opt/Autodesk/shared/export/presets/file_sequence: Permission denied
rm: /opt/Autodesk/shared/export/presets/movie_file: Permission denied
rm: /opt/Autodesk/shared/export/presets/sequence_publish: Permission denied
rm: /opt/Autodesk/shared/export/presets: Permission denied
rm: /opt/Autodesk/shared/export: Permission denied
rm: /opt/Autodesk/shared/fbx: Permission denied
rm: /opt/Autodesk/shared/import: Permission denied
rm: /opt/Autodesk/shared/presets: Permission denied
rm: /opt/Autodesk/shared: Permission denied
rm: /opt/Autodesk/sparks: Permission denied
rm: /opt/Autodesk/sw/autodesk_folder_icns.tgz: Permission denied
rm: /opt/Autodesk/sw/cfg/.sw_serverd.cfg.base.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/.sw_serverd.cfg.server.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/stone+wire.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/stone+wire.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_bwmgr.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_bwmgr.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_dbd.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_dbd.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_framestore_map: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_framestore_map.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_probed.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_probed.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_serverd.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_serverd.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_storage.cfg: Permission denied
rm: /opt/Autodesk/sw/cfg/sw_storage.cfg.sample: Permission denied
rm: /opt/Autodesk/sw/cfg: Permission denied
rm: /opt/Autodesk/sw/log: Permission denied
rm: /opt/Autodesk/sw/sw_bwmgr: Permission denied
rm: /opt/Autodesk/sw/sw_changePathsRoot: Permission denied
rm: /opt/Autodesk/sw/sw_dbd: Permission denied
rm: /opt/Autodesk/sw/sw_depend/ifffsWiretapServer.sw_depend: Permission denied
rm: /opt/Autodesk/sw/sw_depend/README: Permission denied
rm: /opt/Autodesk/sw/sw_depend: Permission denied
rm: /opt/Autodesk/sw/sw_df: Permission denied
rm: /opt/Autodesk/sw/sw_ping: Permission denied
rm: /opt/Autodesk/sw/sw_probed: Permission denied
rm: /opt/Autodesk/sw/sw_purge: Permission denied
rm: /opt/Autodesk/sw/sw_restart: Permission denied
rm: /opt/Autodesk/sw/sw_serverd: Permission denied
rm: /opt/Autodesk/sw/sw_sh_lib.sh: Permission denied
rm: /opt/Autodesk/sw/sw_sh_lib_mac.sh: Permission denied
rm: /opt/Autodesk/sw/sw_start: Permission denied
rm: /opt/Autodesk/sw/sw_stop: Permission denied
rm: /opt/Autodesk/sw/sw_version: Permission denied
rm: /opt/Autodesk/sw/sw_waitfornetwork: Permission denied
rm: /opt/Autodesk/sw/tools/.db_dump: Permission denied
rm: /opt/Autodesk/sw/tools/.db_load: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateClip: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateGatewayClip: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateManagedVideo: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateUnmanagedAudio: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateUnmanagedVideo: Permission denied
rm: /opt/Autodesk/sw/tools/sw_allocateUnmanagedVideoStream: Permission denied
rm: /opt/Autodesk/sw/tools/sw_bwm_device_speed: Permission denied
rm: /opt/Autodesk/sw/tools/sw_destroyFrames: Permission denied
rm: /opt/Autodesk/sw/tools/sw_dumpFrames: Permission denied
rm: /opt/Autodesk/sw/tools/sw_errCodeToStr: Permission denied
rm: /opt/Autodesk/sw/tools/sw_fid: Permission denied
rm: /opt/Autodesk/sw/tools/sw_framestore_dump: Permission denied
rm: /opt/Autodesk/sw/tools/sw_freespace: Permission denied
rm: /opt/Autodesk/sw/tools/sw_generateFramestoreId: Permission denied
rm: /opt/Autodesk/sw/tools/sw_getFrameInfo: Permission denied
rm: /opt/Autodesk/sw/tools/sw_getFramestoreFormatPrefs: Permission denied
rm: /opt/Autodesk/sw/tools/sw_getIntermediateProfileCodecs: Permission denied
rm: /opt/Autodesk/sw/tools/sw_io_perf_tool: Permission denied
rm: /opt/Autodesk/sw/tools/sw_isCompatible: Permission denied
rm: /opt/Autodesk/sw/tools/sw_md5sum: Permission denied
rm: /opt/Autodesk/sw/tools/sw_modifyRefCount: Permission denied
rm: /opt/Autodesk/sw/tools/sw_read: Permission denied
rm: /opt/Autodesk/sw/tools/sw_read_audio: Permission denied
rm: /opt/Autodesk/sw/tools/sw_read_av: Permission denied
rm: /opt/Autodesk/sw/tools/sw_reftool: Permission denied
rm: /opt/Autodesk/sw/tools/sw_setRefCount: Permission denied
rm: /opt/Autodesk/sw/tools/sw_test_allocate: Permission denied
rm: /opt/Autodesk/sw/tools/sw_test_allocate_audio: Permission denied
rm: /opt/Autodesk/sw/tools/sw_view_image: Permission denied
rm: /opt/Autodesk/sw/tools/sw_view_image_file: Permission denied
rm: /opt/Autodesk/sw/tools/sw_view_image_mio: Permission denied
rm: /opt/Autodesk/sw/tools/sw_wiretap_ping: Permission denied
rm: /opt/Autodesk/sw/tools/swdb_recover: Permission denied
rm: /opt/Autodesk/sw/tools: Permission denied
rm: /opt/Autodesk/sw: Permission denied
rm: /opt/Autodesk/user: Permission denied
rm: /opt/Autodesk/wiretap/cfg/wiretap_path_translation_db.xml: Permission denied
rm: /opt/Autodesk/wiretap/cfg/wiretapd.cfg: Permission denied
rm: /opt/Autodesk/wiretap/cfg: Permission denied
rm: /opt/Autodesk/wiretap/previous: Permission denied
rm: /opt/Autodesk/wiretap/tools/previous: Permission denied
rm: /opt/Autodesk/wiretap/tools: Permission denied
rm: /opt/Autodesk/wiretap: Permission denied
rm: /opt/Autodesk/wiretapgateway/cfg/wiretapgateway.cfg: Permission denied
rm: /opt/Autodesk/wiretapgateway/cfg: Permission denied
rm: /opt/Autodesk/wiretapgateway/previous: Permission denied
rm: /opt/Autodesk/wiretapgateway: Permission denied
rm: /opt/Autodesk: Permission denied
Message 7 of 15
yann.laforest
Can you please explain what you did exactly to get those error messages?
Also, do you expect to have the trial build installed along with other Autodesk products on your workstation or the trial build alone?
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 8 of 15
yann.laforest
Hi Beth,
While reviewing the error messages log, I noticed that one command you ran had a bad argument.
sudo -su should be sudo su
Can you please give a try again but with the sudo su command instead and see if it solves the issue?
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 9 of 15
mh
Hi Beth,
As Yann said the sudo command doesn't use -su for superuser access. Hopefully it's as simple as that. If you still run into issues you should verify if csrutil is disabled by opening Terminal on your system and paste the output of the status command. It will show either enabled or disabled.
MacBook-Pro:~ markholloway$ csrutil status
System Integrity Protection status: enabled.
If the output shows "enabled" you must disable the csrutil using the steps below:
4. Type "reboot"
Message 10 of 15
colbtron
I guess I'll continue to use After Effects until Autodesk gets their heads out of their a$$es. I'll save 500 bucks a month too.
Message 11 of 15
colbtron
I own other Autodesk software, will removing the Autodesk folder to reinstall the Flame trial be a good idea?
Message 12 of 15
yann.laforest
Contact me offline at yann.laforest@autodesk.com and I will assist you with the issue.
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 13 of 15
mchesnay
Hello colbtron,
Instead of deleting the folder, use the Uninstaller located in Flame's Utilities folder (Applications>Autodesk>Flame>Utilities). This ensures that Flame will be removed completely and correctly. Then you can reinstall the trial.
hope this helps.
Martin
Martin Chesnay
Learning Content Designer — EMS-Flame
Message 14 of 15
colbtron
Since the installer doesn't create a Flame folder on my home Mac Pro, I didn't get an Utilities folder! But I'll try copying the one from the office machine and then trying.
Crossing my fingers! Thanks
Message 15 of 15
colbtron
Of course, that didn't work. I was able to uninstall the directories by becoming a superuser, something I was not already although I assumed I was. Here's instructions on setting up a "root" user: https://support.apple.com/en-us/ht204012
Once you've done that, the following commands will work:
as super user, type the following commands in a terminal:
rm -rf /usr/discreet/
rm -rf /Library/Application\ Support/Autodesk/
rm -rf /Applications/Autodesk/
pkgutil --pkgs | grep autodesk | xargs -n1 pkgutil --forget
