Hello Everybody,
I wonder what is the best way to archive & delete Flame projects to free space on the system boot drive.
Archive project / sequences is ok for me. (Include render and cache)
Is it better to Cache Media on Archive ? Because it's heavy !
Cache Media on Archive [ON] + Include Renders => (1.77 TB)
Cache Media on Archive [OFF] + Include Renders => (179 GB)
Cache Media on Archive [OFF] + Exclude Renders => (16 MB)
And when the archive is done in external storage solution (NAS for me), What is the right way to delete project ?
Thank you
Shiver
There is some good advice here:
In Flame 2016x2 I'm regularly seeing jobs that are archived as cached. But when I open the archive, it restores as uncached. So unless the original material is on the server, I'd be stuffed. I've seen this many times, between many different machines. And was able to verify on the original machine that it was still cached on the original machine. It happened to me agaIn yesterday. Weird things happens like hard committed clips come in with a "mixed" status.
I'd recommend working with an uncached workflow as probably the safest, and backup your job directories outside of the Autodesk archive. and double check the integrity of the archive that you do make. I'd make a backup of the OTOC contents and keep it with the archive
re: deleting projects:
http://help.autodesk.com/view/FLAME/2018/ENU/?guid=GUID-7F43A9A3-C997-4846-8381-69D8F6CF1B2E
To delete a project:
Peter
Archive
Dear Shiver,
which is the best way, really according to your flame workflow and IT equipments.
1.77TB huge, but easy and clean to return customs,
who might backup it or revised next time.
as some of my clients, which are post production house based in shanghai,
they have not permission to keep production/agency source material.
179GB seems nice,
for cheaper imac and mac pro,
after TVC generic version present,
remain jobs are easy to an assistants,
one studio i served, they like to do this.
from linux workstation to an iMac, and hand off to assistant to do,
such as add subtitles/lyrics, id card, countdown, final delivery mastering, etc.,
16MB is good for a sound SAN material + DAS caching env
and good Linux workstation is enough faster to rendering Timeline FX or BFX.
SAN material would be backup by IT department to Tape or Nearline
flame archive (might only setups) should to copy to another project folder (NAS, collabrative)
after job closed, producer will make it offline, such as a DVD burn copy, usually after chinese new year.
finally, i hope my baddest english would be understand 🙂
Yours Lovely,
Samuel G. L.
Hello Samuel,
Thank you, it was what i excepted. I chose the 178 Go solution for my workstation (Mac Pro + 10Gbe NAS).
Don't want to re-render every clips / BFX...
Thank you
