Nice tut, as we have come to expect from you 🙂
I have a question: How do you replace media in the time line, while keeping the timeline fx? Currently, I put the new media in the layer above, copy the timeline fx from the old segment, and then replace the new segment over the old.
Surely there must be a shortcut.....
Hello @mauryGEKKZ
The tutorial Joel directed you to uses what you are looking for, but doesn't explicitly mention it. The key here is to use the Replace Media function / shortcut instead of the Replace one.
Finally, the Smart Replace shown by Grant in the tutorial is new to the 2017 version, but the Replace Media is not. It will be available to you if you use an older version.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Cheers
fred
Gestural Replace is not supported (Replace or Replace Media). Only Overwrite and Insert are possible.
Please register to the Flame Feedback program at flamefeedback.autodesk.com and submit an Improvement request for it.
fred
