Z axis indexing on UMC-750 posting to wrong rotary
wmtcoinc
wmtcoinc
When I use Z axis indexing on UMC-750 posting to wrong rotary, and the Sim shows tool working in the X+ side of the table while posting commands moves in the x- side.  All the rotary move are in the B rotary, not the C rotary.
Replies (9)
abhishek.juvekar
Hi @wmtcoinc ,
Thanks for raising your query on Autodesk Forum.
Set the Spindle located at C = 0 in stock indexing. You will also have to set the condition in the post-processor.
Now check the code.
Thank You
Abhishek
wmtcoinc
where is that located in the Stock FeatureCam post for the UMC 750?
wmtcoinc
The stock post looks like this for linear moves.
<IF>[restart_tcpc]<THEN>
{N<SEQ> }G0 G234 X<X-COORD> Y<Y-COORD> Z<Z-COORD> H<OFFSET-NUM> <COOLANT><EOB>
{N<SEQ> }M13<EOB>
{N<SEQ> }M11<EOB>
{N<SEQ> }G1<EOB>
[:tcpc=true]
[:restart_tcpc=false]
<ELSE>
{N<SEQ> }{<MOTION> }{<PLANE> }{<COMP-STAT> }
<IF><COMP-START><THEN>
<BOL> D<COMP-NUM><32>
<ENDIF>
<IF><IS-INC-MAC><THEN>
{X<@X-COORD> }{Y<@Y-COORD> }{Z<@Z-COORD> }F<FEED><EOB>
<ELSE>
{X<X-COORD> }{Y<Y-COORD> }{Z<Z-COORD> }{B<ROT1-WIND> }{C<ROT2-WIND> }
<IF><COMP-3D-ON><THEN>
I<X-SRFNORM> J<Y-SRFNORM> K<Z-SRFNORM><32>
<ENDIF>
F<FEED><EOB>
<ENDIF>
<ENDIF>
abhishek.juvekar
Hi @wmtcoinc ,
I am not the post-processor expert. But I have attached the modified fm file and standard post with necessary modifications. Can you please take a look and if this doesn't help, please create a support case for post-processor team?
Thank You
Abhishek
wmtcoinc
That fixed the rotary ID thing , but it doesn't fix the x axis over travel the the plus direction.  The UMC-750 has 30" of X travel.  About 11" in X+ and 19" in X- center to the table.   This means the the milling in the sample must be done in the X- side of the table or you will travel limits.  Your sample run past the X+ machine travel limits. How can I force the post to do this so the Z axis indexing will work on this machine?
Russ F.
wmtcoinc
After years of trying the fine the fix , still no answer!!!!!!
wmtcoinc
Well , since no one in this forum can figure this problem out, I left a phone massage with my Rep, and he din't return my call.
Russ
Mikhail_Voronin
Hi @wmtcoinc
Maybe this can help you.
________________________________________
Mikhail
wmtcoinc
Mikhail_Voronin your not doing a Z axis indexing cut.  This program would run out of X travel.
Thanks anyway, Russ
