FeatureCAM Forum
Welcome to Autodesk’s FeatureCAM Forums. Share your knowledge, ask questions, and explore popular FeatureCAM topics.
Will PartMaker not update its functions anymore?
1 REPLY 1
162 Views, 1 Reply
Is it impossible for Partmaker to perform face milling in cylindrical milling? For example, chamfering the side of the inner hole on the end face?
Is there any other method? When I use cylindrical milling and face machining, it cannot be simulated in the software.
1 REPLY 1
Hello 2649063614
It sounds like you want to use the Face Window set to machining function of Mill End Polar. That Face Window will create a tool path that rotates the part. If that doesn't help are you able to share a solid model with the feature in question?
Bill Cain
Sr. Technical Consultant
