Anuncios
Warning Tpp02w and Tpp03w Cant find ramp-in-arc, Cant find ramp-out-arc
No aplicable
Please Help, I have gone and changed the lead in and lead out approach angels but still get the same error code!  What am I doing wrong? I have also attached the posted program if that helps!
0 Me gusta
Responder
540 Vistas
2 Respuestas
Respuestas (2)
jeff.brower
The code looks like it will work, the straight lead-in and -out isn't ideal but should work.
I'm guessing the tool is too large for the software to compute a radius type lead-in / -out.
attaching the file helps, thanks.
0 Me gusta
abhishek.juvekar
Hi @Anonymous,
Thanks for raising your concern through Autodesk Forum!
It seems tool is not getting enough space to ramp in/out because the ramp diameter percentage is set to be 50% of tool dia in roughing attributes of thread milling feature.. If I decrease the percentage (I set it to 10%), the warning disappears. Can you please verify?
If my post answers your query, please click on 'Accept as Solution' button.
Thank You.
Abhishek
0 Me gusta
