I am writting an exe file to get the all hole features, and change it's diameter and depth if there are not my want.
the code i wrote:
Dim docHole As FeatureCAM.FMHole = docFeatrue
If Not (docHole.Diameter = feature.Diameter) Then
docHole.SetAttribute( attr_id, sub_id, feature.Diameter)
here is the enumerate attr_id and sub_id.
can somebody give me help, and write an example for me?
Hi @hx,
To change the diameter and depth of a hole, you can use the following code...
Dim hole as FMHole
hole.Update3(,Diameter,Depth)
You do not need to use an AttributeID for modifying these parameters, just replace Diameter and Depth in the above code.
The FeatureCAM API help is a great resource when writing macros. It can be found by selecting the ? icon in the top right of the FeatureCAM window, and selecting FeatureCAM API Help.
Hope this helps,
Spencer
