Anuncios
Use Solids As Clamp Error ( CAN'T See this Solids)
tony.huangXJQQN
Observer
tony.huangXJQQN
Observer
Observer
Hello everyone,
I have a problem..
I use solids as clamp on FeatureCAM 2022.
But go run simulation. can not see clamp solids..
Has anyone encountered this before?
Regards
Tony Huang from Taiwan
0 Me gusta
Responder
419 Vistas
1 Respuesta
Respuesta (1)
julio.romerodarocha
Did you import that vise from the addin import vise? If the answer is yes, It should be the sólid as clamp by default and work without any issue.
In any case, try to set up that sólids as clamp by another way, select de sólids but touching the solid/right mousse button/ select the solid/right button again over the selected solid/use solid as a clamp  , not in the tree of sólids( in the left side of the screen)
I Hope It works, if not, share the .FM project if you want.
0 Me gusta
