Anuncios
undercuts on a lathe
shawn.klug
Observer
shawn.klug
Observer
Observer
I'm trying to turn a 1.5" hex shaft down to .5, using a left and a right hand 55deg tool. It starts ok, then starts rubbing/cutting on the back side of the tool, this tool should cut a 30 deg. cut no problem, then it starts hitting/cutting  on the backside of the insert before it gets to it finish diameter.
0 Me gusta
Responder
391 Vistas
1 Respuesta
Respuesta (1)
TomOliver
It may not cut a 30 degree no problem. Look at the picture below from Iscar's website. This is for a DNMG with a 93 degree approach. 27 degree is the max.
https://www.iscar.com/eCatalog/Applications.aspx?mapp=IS&GFSTYP=I
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
