Tool path off of geometry
No aplicable
I have some slots that need to be cut on the face of a part.  The slots are 1.5 mm wide and .3 mm deep.  I want to run a 1.5 mm end mill down the center of the slot to finish it.  I created a curve along the edge of the slot and wanted to run the cutter on the left side of the curve.  I can not figure this out.  Can someone help me with this?  So how do I drive a cutter on the left side of a curve for 2D machining?
0 Me gusta
Responder
Soluciones aceptadas (1)
423 Vistas
2 Respuestas
Respuestas (2)
No aplicable
Solución aceptada
You should be able to do that with a Side feature.  But if you just want to run a centerline path, you could also create a curve on center and use a simple groove.
0 Me gusta
No aplicable
Thank you
0 Me gusta
