Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
FeatureCAM Forum
Welcome to Autodesk’s FeatureCAM Forums. Share your knowledge, ask questions, and explore popular FeatureCAM topics.
Tool cribs are showing empty.
0 REPLIES 0
Message 1 of 1
bmarkeyJ44PH
264 Views, 0 Replies
The way I work is I have my main crib, this is all 80+ tools that are my standard set.    I start a new document in FC, either with a model or not.  I get enough geometry to add a single feature, usually a face.  Then I save the doc, close it, and reopen it.  Now I'm in the crib for this document.  ( I save tools with the doc, this way my main crib doesn't grow out of control.)
Then as I program I just grab tools from my main crib.   BUT, if I'm working on a bunch of parts that all go together, and they share tools, like specific taps/drills etc, I can just add those from the crib of another part.  So for example part A I use a .281 drill, this is not standard in my main crib.  I finish that and start a new part, this also needs that drill, so I just grab it from the crib from part a.   This works wonderfully, usually.
I'd say maybe 30-40% of the time it just shows an empty crib from the part I finished, so I can't import it into the current one.  Its just blank, every category.  If you open that part, all the tools are there. So I guess my question is why?
See attached.  Currently I'm working on the _004 part and trying to pull in from the _003 part.   _003 shows a totally empty tool crib, even though the tools are obviously there.  In the second picture I'm in the _003 doc and you can see its on the right crib, tools are present but it still shows the crib as empty.  How do I fix this?     This never happens with my  main crib, only on cribs that are part of a doc, and like I said its not all the time.
Bruce
Tags (3)
Labels (1)
0 REPLIES 0
