Thread milling
Thread milling
Message 1 of 9
Thread milling
I have a part that I need to thread mill some holes into it.  The thread mills that we use here have a endmill on the end of it so I do not have to drill a hole.  I just run the thread mill into the hole and it bores it and threads it at the same time.  Doing it this way I have to run the spindle in reverse and the thread mill has to start at the top down going counter clock wise.  I can figure out how to get Featurecam to do this.  Does anyone have any ideas?
Replies (8)
Message 2 of 9
Hi @Anonymous,
Is it something like this you need?
What type of tool you use? HITACHI thread mill or?
Message 3 of 9
Yes, I use hitachi.  Thank You that works.  I ran one hole and I had to comp it back about .005".  I had the right size dia on the tool but it went a little big.  I put in a 1/4-20 hole.  That is the only problem that I had.
Message 4 of 9
meckdie
Hello.
I am trying to learn to use a Hitachi 1/4-20 thread miil / tap also.
(I am COMPLETELY NEW to thread milling)
Question:
What do I do with this .fm file ?  Save it where?
Thanks, Mark
Message 5 of 9
Hi @meckdie,
Can this be used?
Message 6 of 9
meckdie
Well I failed to realize in my "search", that your post is in "FeatureCam", not "Fusion 360".
I'm guessing that is why I cannot figure this out.   my bad.
I don't suppose you have any experience with doing this in Fusion?
Thanks, Mark
Message 7 of 9
Hi @meckdie,
Great:-)
Yes I do, but haven't more time yet:-)
I will do later if I have the time.
Message 8 of 9
Hi @meckdie,
I would try this settings.
Remember to set the pitch, this is for mm.
Message 9 of 9
meckdie
Awesome!
Thank you for your help!!!
Thanks, Mark
