Anuncios
text
text
No aplicable
I need to engrave numbers on some parts that need to be .040 tall.  I go to create the text and the only thing that I see is to tell it the height of the text is scaling.  I have no idea how to get featurecam to give me a height of .040 tall.  Can somebody explain this to me.  I am confused about this.
0 Me gusta
Responder
Soluciones aceptadas (1)
607 Vistas
8 Respuestas
Respuestas (8)
jeff.brower
yah, text is a little wonky.
You can change the size of the text in the font dialog, a size 20 is .250 inch tall and a size 10 is .125 inch tall.
You need to use a combination of font size and scaling to get good results, sometimes using very small font sizes will produce poor results so use a larger font size and scale it down.
I usually draw a box for size and location then use it as a guide for making the text fit. Fortunately it's easy to edit and change the text.
Don't think we've made text that small, usually .125 tall here.
bhorstTGM48
Solución aceptada
It was explained top me a long time ago by FC support staff. When you choose your font ALWAYS choose a font size of 72. Then in the Scaling: you put whatever size you want for your text. In your case you would use .04 in both boxes. This works really well and the size of the text comes out pretty close.
jeff.brower
That's very helpful, thanks!
No aplicable
Thank You.  That worked
0 Me gusta
No aplicable
That is really helpfull (always make the font size 72)  Thanks!
bhorstTGM48
Glad I was able to help :cara_con_una_leve_sonrisa:
0 Me gusta
No aplicable
OK, 72 and use Scaling. Works very well. Is the 72 based on 1 inch? Quite that does not fit, different from font to font. I measure the letter in 72, calculate the wanted size divided by the measured size to 72. The result is the scaling in X and Y to enter. Fits 100%. From the desired size please deduct the width of the engraving before. In my case, width 0.4 mm. Which fonts are at FC Einzeilig? Which font is best for single-line engraving of text? Which typefaces do you use to engrave single-line text? Fonts have to be experimented for a long time to get an accurate result! Would like to get to know your experiences closer! Would be very grateful. In the font I use machine tool SanSerif, gives a reasonable look of the font. All others are not really usable, more or less! At least for one-line engraving! I look forward to the knowledge of you. Thank you in advance! I post a screenshot of all settings, so you can do everything after. Sincerely, Mathias Beyer and let your experiences come here.
OK, 72 und Skalierung verwenden. Funktioniert sehr gut. Ist die 72 auf 1 Zoll bezogen? Ganz passt das nicht, abweichend von Schriftart zu Schriftart. Ich messe den Buchstaben in 72, rechne die gewollte Größe geteilt durch die gemessene Größe auf 72. Das Ergebnis ist die Skalierung in X und Y zum Eintragen. Passt zu 100 %. Von der gewollten Größe bitte vorher die Stichelbreite noch abziehen. In meinem Fall Breite 0.4 mm. Welche Schriftarten sind bei FC Einzeilig? Welche Schriftart am besten geeignet für einzeilge Gravur von Text? Welche Schriftarten verwendet ihr zur Gravur von Text Einzeilig? Schriftarten muss man erst lange Experimentieren um ein genaues Ergebnis zu bekommen! Würde gerne eure Erfahrungen näher kennen lernen! Wäre sehr dankbar. Bei der Schriftart verwende ich Maschine Tool SanSerif , ergibt ein vernünftiges Aussehen der Schrift. Alle Anderen sind nicht wirklich verwendbar, mehr oder weniger! Zumindest für einzeilige Gravur! Ich bin gespannt auf gemachtes Wissen von Euch. Danke im Voraus! Ich poste noch ein Screenshot von allen Einstellungen, damit kann man alles nach vollziehen. Mit freundlichen Grüßen Mathias Beyer und lasst eure Erfahrungen hier zukommen.
0 Me gusta
No aplicable
I use the machine tool sans serif often as well as machine tool Grenada. Another option is to go to http://www.onelinefonts.com/ and you can download other single line fonts, but unfortunately they arent free. You only have to buy them once though....
