Anuncios
Supressing Output of Y-axis on turret on CitizenM32III wit Featurecam Partmaker
No aplicable
Our Post processor outputs a Y-axis when you work with the turret on the main spindle.
If you have created a program and generate it, you will see that a Y-axis value is issued when you start working on the main spindle with the turret
($ 2). When sending your tools to your switch point.
If I want to change this in the post processor it comes with error messages and changes things in the post processor that I do not want to have changed.
I Had this problem also if  working with the turret ($ 2) on the subspill, but it was solved by deleting the output token for Y-axis
(PROCESS 2 GAT-5.0)
T2000 (C.B.D-6.0 H-90)
G50 U50.0 W0. (LOAD OFFSET)
G97 S1 = 1000 M3 M96
G99 G0 Z-1.0T20
X0.
G1 Z3.0 F0.1
G4 U1.0
G0 Z-1.0
G50 U-50.0 W0. (CANCEL OFFSET)
G97 G0 X180. Y0.0 T0
I would like to suppress the output of Y0.0 could someone please help me in doing so
Greetings Ray
0 Me gusta
Responder
381 Vistas
1 Respuesta
Respuesta (1)
phil.jenningsM7ZMZ
Info,
load your files into Partmaker then use the blue telephone icon at the top of the page to zip the files.
send them to me and i will set you up with a post mod request.
Send to phil.jennings@autodesk.com
thanks, phil
Philip Jennings
Technical Support Team Leader
0 Me gusta
