Anuncios
Solid modeling question.
No aplicable
Hello everyone.  1st post here.  I'm a programmer that's used featurecam for about a year and I'm pretty much learning as I go.  Anyway... is there a way to mass edit a solid model?  I'm extruding hole patterns and would like to extrude the whole pattern at once vs one at a time.  Not sure if this is even possible so I'll ask the experts.  Thanks
0 Me gusta
Responder
Soluciones aceptadas (1)
638 Vistas
2 Respuestas
Respuestas (2)
jeff.brower
Solución aceptada
I don't think there is a way to make a bunch of holes in a solid all at one time with geometry. However if you create the machining feature as a hole pattern first, then you can modify the solid with "From Feature" command in the Construct, Solids, From Surfaces, From feature menu.
No aplicable
Thanks!  Learning more day by day.
0 Me gusta
