Anuncios
side feature with draft not finishing all the way to the bottom
TomOliver
TomOliver
I've created a file of a problem I'm having on other parts. I want to put a large weld bevel  (45 degree) on the side of a 1" thick plate. I want to rough this with an end mill and finish with a chamfer mill. Featurecam roughs just fine; however, It doesn't want to finish the chamfer mill all the way to the bottom. Any suggestions?
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
Responder
Soluciones aceptadas (1)
625 Vistas
11 Respuestas
Respuestas (11)
No aplicable
Probably there are a bug to how the tool be calculated. Because if you put an extra material on X-minus then you can run to the bottom. see link.,
https://www.screencast.com/t/pABfGEsl
https://www.screencast.com/t/7t1S5a0Wneio
Jacob
TomOliver
Jacob,
This did work on the sample file I sent you. However, with the part I am actually working on, I have cut a stock curve and X and Y move are grayed out.
I've attached that file.
Tom
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
No aplicable
Hi Tom,
Most of cases I think it's easier to create a surface. See the attached file. I ahve tried to make a toolpath with "isoline" and "z-level"
Jacob
0 Me gusta
TomOliver
Yes. I have tried that in the past. The code is always longer even after arc fitting the output options. I will try it again and see if I have any luck.
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
No aplicable
What kind of postprocessor you use?
0 Me gusta
TomOliver
Control is a 15M. Post Processor started out as a Haas Post.
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
No aplicable
So if I understand right the controller is a Fanuc and the postprocessor you use is for a haas?
Jacob
0 Me gusta
TomOliver
Yes. I started with a Haas post processor and then modified it to fit my machine--Fanuc 15m.
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
No aplicable
In this case for short program I think this is the best shot I have. If you have space enough then you made the feature a little bit deeper. I have tried to adjust then to 1inch, then you have a clean cut. See link. https://www.screencast.com/t/x1mBnIJSbHyR
Jacob
0 Me gusta
abhishek.juvekar
Solución aceptada
Hello @TomOliver,
Keeping Total Stock in the attributes seems to work. Can you please check?
Thank You
Abhishek
0 Me gusta
TomOliver
@abhishek.juvekar This seems to work. The total stock has to be added to the rough milling attribute. The roughing toolpaths have always worked. I have tried total stock in the finishing milling attributes with no luck. However, adding it to the rough milling worked.
Autocad LT
FeatureCam Ultimate
Fusion 360
0 Me gusta
