Setupsheet issue FeatureCAM 2018
Dear Team,
I have problem setupsheet in Feature CAM 2018. The output results do not match the program parameters.
for detail check attachment.
thanks ,
Mada Kharisma
It looks like there are a mismacth how to read the parameter from the setup sheet.
It need to be passed on Autodesk, so development can take action.
Thank you,
Jacob
I have seach some more, and after time there must be something strange with you document, I have tried to program the part from start with new names, and used your setupsheet, it's works perfect.
See link.
https://www.screencast.com/t/8kwTjSjWh
Thank you,
Jacob
Thank you for your help ,
I've tried by making new and successful.
I try to use setupsheet in version 2017, and I have a problem, not all time appears in every process. view image
I have the same problem. It often happen when there are hundreds of holes with Pattern function in FeatureCAM 2018 (Mill mode).
Eamon
bhorstTGM48
Sometimes I have to delete the current Setupsheet and create a new one in order for it to update.
