Save Results
Save Results
Save Results
If you save results of a simulation and then start a simulation of another setup with the origin in a different spot from the first setup, the simulated results are in the wrong location.
abhishek.juvekar
Hi Shawn,
Thanks for posting on Autodesk Forum.
I verified the  above behavior and not able to reproduce. Is it possible for you to share the fm file?
Thank You.
Abhishek
I was able to replicate it in another quick file I made.  I could not share the original file.
It seems to work if I do both at once, but if I do setup 1, save results, then run setup 2 with only a drill hole.  The drill doesn't drill into the stock.
abhishek.juvekar
Hi @Anonymous,
I was thinking with regards to save simulation results but it seems to be with Use Results as Starting Point.
Thanks for supplying the part and providing additional information which helps me to reproduce the above behavior with Use Results as Starting Point.
Development team is aware of this behavior via a change request reported by other customers. I have added your additional comments to the task.
Thank You.
Abhishek
