Anuncios
Rough machining with Z level - problem.
No aplicable
Hello.
I have problem with rough machining. All tool paths are generated to max. height and whole cross-section. E.g. cone. Semi finished product and finish item is cone.  It makes tool paths as machining roller and machining air. What should I do to remove empty paths and fit rough paths to real shape? Thanks.
0 Me gusta
Responder
268 Vistas
2 Respuestas
Respuestas (2)
No aplicable
Hi @Anonymous,
Can you share your file?
No aplicable
Ok. Too fast post here... I found and changed to third option (Use solid) First is object surface dimensions, second use stock dimensions:
Now, it recognizes real stock shape.
It was revelation, sorry for post ;] But thanks for reaction. Greetings!
0 Me gusta
