FeatureCAM Forum
Welcome to Autodesk’s FeatureCAM Forums. Share your knowledge, ask questions, and explore popular FeatureCAM topics.
Recent files wrong, s/f's disappear, tool cribs don't show tools.
2 REPLIES 2
bmarkeyJ44PH
259 Views, 2 Replies
So I'm at my wits end with FC.  Running 2024.0.1.13 and its constantly flaky.
Main issue currently is that speeds and feeds are just gone one day, here another.  I don't understand what is going on.  I'm the only that uses this pc, nothing has been changed but again today all drilling and tapping s/f's are gone, no matter what material. They worked yesterday?!   What actual files holds this information?  Is there some sort of logging I can turn on to see what is erroring or why they're all gone?
Recent files may or may  not actually show the most recent files.  I'll go to open a file I was working on a few hours ago, not there.
Tool cribs, again sometimes it works, sometimes not.  I use the "save crib with document".  I can open a document and the tools are there, but say I want to pull a tool from another crib, nope, shows the crib but it shows empty.  If you open that file, the tools are there. Again, what files actually hold this information?  If I can see the crib why does it act like its empty?
This shouldn't be that complicated, yet I fight with this weekly.   I've already removed all the autodesk programs and reinstalled.  Works for a bit, then back to this intermittent weirdness.
Looking for some direction here.
2 REPLIES 2
bhorstTGM48
in reply to: bmarkeyJ44PH
I would try right clicking on the FC icon and selecting "Run As Administrator"
bmarkeyJ44PH
in reply to: bhorstTGM48
I did try that, same outcome unfortunately.   The only speeds and feeds that are kept are those that are set per tool.  Everything else is gone, but will reappear randomly in a day or few.   Thats all drills, taps, and anything else that didn't specifically have s/f's associated with the tool.
Even weirder is that its only gone for certain types.  So all my hss drills are gone, there still seems to be s/f's for carbide drills, which I don't use.
The other think I noticed is that for some reason on random files it creates a separate material like it does with the crib.    So the part I have open now, that I worked on  yesterday and was created with material Steel 41xx, now shows that its using file_name_steel_41xx, which is really odd.
What file(s) hold the s/f tables?
