Programming issue
ronald.edwards
Programming issue
ronald.edwards
I am trying to run this part in a Mazak Integrex. I am using Featurecam 2020. The issue is when I try to re-start the program to re-run a tool the machine starts but does not go to the proper X location. On the finish cut the tool should be at 7.249. On the machine control it stops at 10 inches, and thinks it is at 7.249 and starts to cut. I am missing something here but cannot figure out what. Any help is appreciated. I had to post it this way it is an EIA file and my EIA attachment would not send
N15 (NEW C2539-1 12-9-2019)
N20 (MAZAK e 650 H MATRIX CONTROLs)
N25 (PART NUMBER=c2539-1)
N30 (STATUS=)
N35 (MACH=MAZAK)
N40 (BL DRAWING=)
N45 (DATE CREATED - 12-9-2019)
N50 (REVISION=)
N55 (PROGRAM NUMBER=000001)
N60 (LOCATION=FEATURECAM)
( MAIN SPINDLE, TURNING )
( SEMI-FINISH TURN GAGE CUT SHOULD CHECK 7.269 )
N75 G18 G20 G40 G54 G80 G95
N80 G64
N85 M202 ( MAIN TURN MODE )
N90 T3.1 M06 ( GAGE CUT )
N95 G53 G91 G30 P3 X0.
N100 G91 G30 P3 Y0. Z0.
N105 G0 G28 G91 Y0.
N110 M108
N115 G0 G90 B90.0
N120 M107
N125 M212
N130 M239
N135 G92 S550
N140 G97 S263 M204
N145 G10.9 X1 ( DIAMETER INPUT MODE )
N150 G0 G90 G54 Z130.5578
N155 X7.269 Y0. M08
N160 G96 S500
N165 G01 Z124.3573 F0.006
N170 X7.3887 Z124.2537
N175 X7.574 Z124.3463
N180 G0 X8.7
N185 M09
N190 M205
N195 G10.9 X1 ( DIAMETER INPUT MODE )
N200 G53 G91 G30 P3 X0.
N205 G91 G30 P3 Y0. Z0.
N210 G0 G28 G91 Y0.
N215 M01
( FINISH TURN FINISH O.D 7.249 )
( TOOL CHANGE )
N235 G18 G40 G54 G80 G95
N240 G64
N245 M202 ( MAIN TURN MODE )
N250 T3.1 M06 ( FINISH_TURN_55_RH )
N255 G53 G91 G30 P3 X0.
N260 G91 G30 P3 Y0. Z0.
N265 G0 G28 G91 Y0.
N270 M108
N275 G0 G90 B90.0
N280 M107
N285 M212
N290 M239
N295 G92 S500
N300 G97 S237 M204
N305 G10.9 X1 ( DIAMETER INPUT MODE )
N310 G0 G90 G54 Z130.5553
N315 X7.249 Y0. M08
N320 G96 S450
N325 G01 Z124.3573 F0.006
N330 X7.3687 Z124.2537
N335 X7.554 Z124.3463
N340 G0 X8.7
N345 M09
N350 M205
N355 G53 G91 G0 X0.
N360 G91 G30 P3 X0.
N365 M30
0 Me gusta
Responder
418 Vistas
6 Respuestas
Respuestas (6)
No aplicable
Hi Ronald
Or tour simulation is ok in FCAM
Then the problem is in the post itself
Have a Nice day
0 Me gusta
No aplicable
If your finish cut is really supposed to be at 7.249 then this probably isn't a programming issue. Your issue is at the machine. If this is only happening when you go to restart the tool, make sure you are starting all the way back at the toolchange or the M1 at the end of the previous op. My guess is you're starting further down the code and it's not picking up the tool and work offset.
If this is happening on every run, and not just when you go to restart a tool, then doublecheck your work and tool offsets.
0 Me gusta
ronald.edwards
We are starting at the M01 from the previous operation
0 Me gusta
ronald.edwards
I am wondering if the G10.9 at the end of the process is causing the issue. I am going to block skip it when the operator comes in.
0 Me gusta
No aplicable
Just to clarify, the whole program ran through once right? Is this purely an issue with re-running a tool or are you having trouble with the finish pass every time?
0 Me gusta
ronald.edwards
That is a section of the program. The program will run correctly if we start from the beginning. When it is re-started it loses the X. Sometimes we cant. What I need to clarify is that it restarts but the x is in the wrong location. The problem occurs when we re start a specific tool.
0 Me gusta
