Problems drawing a j slot
No aplicable
Anybody can tell me how to draw and also what is the best machining option to use ( mill diam, index?)  I’m posting a picture attached with dimensions. I have troubles drawing a “j” slot because it only shows a 29 degree angle and not   a dimension.
0 Me gusta
Responder
666 Vistas
14 Respuestas
Respuestas (14)
kelbie.ockey
When you get a chance, would you mind posting that photo?
Just guessing off of your description, the following articles may be particularly helpful for this. If you are trying to mill a slot around the OD of a part, you will need to make sure that the curve is tangent to the OD, and then just check the wrap option in the feature.
Kelbie Ockey
Sr. Implementation Consultant
No aplicable
Thanks for your response. This is my first time posting in this forum, and when I tried to attach the picture, I couldn’t because the attachment options wasn’t available don’t know why!
0 Me gusta
No aplicable
Also I forgot to mention that I need help drawing and machining a “j” slot in Partmaker. Thanks
0 Me gusta
kelbie.ockey
Ahhhh. I didn't realize it was PMK. @christian.poluch @tatenda.mushonga Any ideas?
Also, for images specifically, I recommend the 'Insert Photos' option. This puts the photo inline with the response as opposed to attaching the file for download.
Kelbie Ockey
0 Me gusta
No aplicable
Im using iPhone X to upload the image but when I do it and try to post I get an error message saying that: “your post has been changed because of invalid HTML was found in the body. The invalid HTML has been removed. Please review the message and submit the message when satisfied.” So how do I upload the image?
0 Me gusta
No aplicable
Since only the formatting of your text for the forum was adjusted. This is very confusing the first time.
Just click on posts again.
I hope it helps?
Da wurde nur die Formatierung deines Textes für das Forum angepasst. Das ist die ersten Male sehr verwirrend.
Einfach noch einmal auf posten klicken.
Ich hoffe das hilft?
0 Me gusta
No aplicable
Upload Image
Bild hochladen
0 Me gusta
No aplicable
Now it should work for you and we want to see pictures. lol
Jetzt sollte es bei dir funktionieren und wir wollen Bilder sehen. lol
0 Me gusta
No aplicable
0 Me gusta
No aplicable
It did work clicking in post again lol!!! Thanks
0 Me gusta
invapprentice
Hi I was looking at your pictures and...Your drawing shows 29 degrees.
I can't see relation to what. The other end shows a pipe thread only.
Regards.
0 Me gusta
No aplicable
The 29 degrees are related to the center of the circle in the j slot.
0 Me gusta
invapprentice
Hi
Sorry. I didn't see it.
Regards.
0 Me gusta
invapprentice
Hi
I attached the FM file.
I hope this my be what you need.
Regards
0 Me gusta
