Problem with turning toolpath
I have some basic problems which I can't figure out why I can't solve it. I have one housing with stock material 0.0625 on a face, and .125 on a diameter and I would like to make my toolpath for roughing just like on an attached process.png file.
Please show/explain to me what I'm doing wrong. Is it a plain problem or something else.
Thank you!
fm file: https://www.dropbox.com/s/4wb1ws2tzjktsk8/housing.fm?dl=0
abhishek.juvekar
Hi @Anonymous,
Thanks for raising your query via Autodesk Forum.
I have modified the project and attached it here. Can you please go through it? There was nothing wrong with the project. Only I had to modify the toolpaths using boundaries in its roughing attributes. Also I had to modify the curves to match up with your requirement.
Please take a look in the attached project and let me know if you have any additional questions.
Thank You.
Abhishek
