Anuncios
Problem whith Setup Sheet
No aplicable
Why when I do my Setup Sheet in some fields don´t show nothing only this symbols  " ---- ".
Regards
0 Me gusta
Responder
351 Vistas
1 Respuesta
Respuesta (1)
spencer.hardcastle
Hi @Anonymous,
Thank you for posting.
The reason why you are seeing the ---, could be due to the following;
- It isn't relevant to the feature/operation/setup (a tag may only be relevant to a surface milling feature)
- The tag has been placed in the setup sheet, outside of a loop (such as operation loop)
As a starting point, you can only use {operation.z_start} and {operation.z_end} for operations where this is set in the milling tab (mainly surface machining features). As a alternative, you could use {operation.depth} or something similar.
Hope this helps!
Spencer Hardcastle
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
0 Me gusta
