posting in camplete error
KarlwTJ54C
KarlwTJ54C
 I'm scratching my head on this one. FC 2018 Ultimate, Featurecam to Camplete ADD IN. This shows up while processing to camplete.
 All my other programs work fine. It's just this one. Any help would be appreciated.
        Karl
KarlwTJ54C
The error occured because I tried to use a Featurecam toolpath M00 for our 5 axis Yasda. It will not work. You can't even "Un-check" the box, it still reads it. So after I post the code from Camplete I manually add the M00 after the tool change. What a screwy work around.
@KarlwTJ54C
Would you know if the camplete add in works with mill/turn?
I read its for 5 axis but I sure hope there is a work around for this
