Post Processor
Post Processor
Message 1 of 13
Post Processor
Hello, I am using Featurecam 2020, When i change programs the post processor does not change, I have to manually change it to the correct one, is there a way to make the post processor stay with the part number?
Replies (12)
Message 2 of 13
This is a great question. I have been dealing with this since we bought a new high speed CNC mill a couple of years ago. Inevitably it will change all my feeds and speeds to my new machines parameters of 60,000rpm vs. my old Haas machines that can only do 7,500rpms max. If I don't catch it well you can guess what the consequences are.
Message 3 of 13
bhorstTGM48
Try enabling this addin, this does the trick for me.
https://www.screencast.com/t/IgExbQbnPHB
Message 4 of 13
Thanks I'll try that
Message 5 of 13
I cant go to that site. company prob has it blocked.
Message 6 of 13
bhorstTGM48
Download that attachment, it is the same screenshot that I uploaded.
Message 7 of 13
Go into your addins click the manage button, library button, scroll down to utilities, and pick save post with docs, click the load button. That should be it
Message 8 of 13
I tried the attachment, it didnt work, govt site here, I went to manage in Featurecam 2020 and the button is greyed out.
Message 9 of 13
You either need someone with administrator rights (most likely problem). Or you may be able to log in as administrator. right click desktop icon click run as administrator. If this is blocked you have no choice but to get whom ever set up the program or computer or your IT guy to let you into it so you can make the changes you need and/or want. So you can do your job more efficiently. There are lots of things in the library that are very helpful. go through all of them and carefully read what they do and if they will help you.
Message 10 of 13
I am the admin for my laptop, I did right click and run as admin and the button is still greyed out
Message 11 of 13
This sounds like one for the applications engineers then. Something isn't working the way it should. I'm surprised none of them have chimed in on this.
Message 12 of 13
Kevin, thank you for your help. I have another question, in 2020 i am trying to mill out a simple pocket but i need the tool at say 45 degrees, when i program the pocket featurecam comes back and says the pocket must lie in the X and Y plane. I assume that means the tool must be perp to the bottom surface. is there a way to have the tool at a 45 angle to machine a pocket?
Message 13 of 13
I am running version 2020.1.0.0011
