Anuncios
Post for Nakamura kl200105
No aplicable
I am new to cam programming and wanted to know if anyone knows what post i can/should use for a nakamura kl200105 y axis lathe. I have been looking around the forums and have seen references to similar machines using a fanuc controller i am a little confused is a controller different from a post processor? and if so what does a controller do. any help/ information would be very much appreciated.
0 Me gusta
Responder
Soluciones aceptadas (1)
477 Vistas
3 Respuestas
Respuestas (3)
tstudley
A controller will be what reads the Gcode and drives the machine, a post processor is what generate the Gcode from the cam software.
0 Me gusta
No aplicable
Thanks for the clarification, would you happen to know where i can find out which post file i should use, if there is a database or something along those lines? or should i contact the manufacturer of the machine. In any case i very much appreciate the help.
0 Me gusta
kamalrajcv
Solución aceptada
Hi @Anonymous
Welcome to Autodesk community.
There are some generic post processor files available within the FeatureCAM installation folder.
(C:\Program Files\Autodesk\FeatureCAM 2019\Posts).
If you cannot find a suitable post processor file in there, I would recommend you to create a support case so that a technical support specialist can have a look.
To create a support case follow this link or create a support ticket from your Autodesk account.
Kamalraj C V
Technical Support Specialist
0 Me gusta
