Pocket is machined smaller than what it should be.
We are making a simple circular piece with 8 equal pockets with a draft angle using a 1" tool and a 0.015 z increment. The problem is that the curve used for the feature has a diameter of 1.99", and when we machined the first pocket, it had a diameter of 1.88". I checked the toolpaths and it was actually only opening to 1.88" instead of 1.99". A quick solution I did was creating a curve with a larger diameter to compensate the difference and it worked. Nevertheless, I want to know the reason this happened, since I can´t find an explanation. Thank you in advance.
Hello @Anonymous
The reason is that your feature is a roughing operation and the Finish allowance is set to .050'', that explain why you were about .100'' or so undersized in diameter on the first run.
Thank you so much! You really helped me since I'm just starting out 🙂
