PartMaker 2021 - Multiple Operations
rgollob
rgollob
Hey everyone,
My team and I are new to PartMaker and I'm wondering how everyone handles turning part setups with multiple operations. Example: I'm clamping on a 2.25" diameter round in a 3 jaw chuck. Completing half the part. Then need to pull the part out, flip, and finish the other side. Pretty simple...
Im using the solid for programming and extracting geometry where needed. I created the setup with the stock and applied the toolpath needed to for that operation.
For the second operation though I'm wondering how others are handling this. I brought in a second model for the second operation and positioned it where i needed it in relation to the coordinate system (since it doesnt appear I can have more then one.) I then put in all the information for that setup. I set the excess as the remaining stock and set the work shift appropriately and finish the remaining operations. The stock boundary shows correctly in the solids window, but not in the wireframe window. When i show the stock in the solids window however it only pulls the stock from the 1st setup and when I simulate it goes straight from the 1st operation and just machines through the part features that were machined on OP1. No flip and the stock is as seen from op1.
How is everyone doing the other setups when you not using a sub spindle to grab the part? Do you make a separate file??
0 Me gusta
Responder
Soluciones aceptadas (1)
535 Vistas
2 Respuestas
Respuestas (2)
jasonWXS2M
Solución aceptada
I think the easiest thing to do would be to program each side separately so you end up with two separate .JOB files, one for the first side and one for the second side. You can generate a .STL file of the first side from the simulation to use as initial stock for the second side: Open the simulation window then press the show finished part button (looks like a light bulb). Next, select "Save Finished Part as .STL File" from the Simulation dropdown menu. When you start programming the second side, select "Define Custom Shape" from the Part Features dropdown menu and use the .STL file from the first side. Of course you could use any solid model for this purpose but this might be convenient.
You'd then have to splice the two programs together by hand or perhaps come up with a simple main/sub program scheme. Not the most elegant solution, I know, maybe some one else will chime in...
~Jason
rgollob
@jasonWXS2M
This is great solution! I dont like the thought of having to do a separate manufacturing file for the additional operations, but I wasnt even aware you could save the finished part from as an .STL and then bring it in as the stock! So this is a big help for us! Thank you
0 Me gusta
