Anuncios
Part line program
Moha789
Part line program
Moha789
Hi
I come from Fusion there we have compensation types: in computer, in control etc..  in other word how the software generates the path based on center line approach  or based on actual dimension on drawing. so how that it works on FeatureCAM? I heard about something called  Part line program?
If I make a milling program in FeatureCAM so what is the default program is it by centerline or actual dimensions?
0 Me gusta
Responder
Soluciones aceptadas (1)
172 Vistas
1 Respuesta
Respuesta (1)
acad-caveman
Solución aceptada
I always hated the "in computer" or "in control" definitions as they can be misunderstood.
In FC the following is implied:
1: No compensation at all: Uncheck "Finish cutter comp" and "Rough cutter comp"
2: Centerline program with wear compensation: Check "Finish cutter comp" and "Rough cutter comp"
I guess that would be equivalent to the " in computer " in that other thing.
3: Full diameter compensation: check both, "cutter comp" and "partline program"
This would be the actual print dimension program. ( in-control equivalent I guess )
