NTX1000 2nd gen simulation problem
For part transfer on NTX1000SZ TurnMill it is necessary to move the lower turret to a safe position (Z-400.) before the sub spindle can move over to the main spindle. In the Slug Transfer window under ,Strategy, Tool Post Control, Lower Turret, I have selected "Escape" position, and index 3 (turret tool 3) for the transfer. In the simulation the turret does indeed rotate to position 3, however the turret remains in the home position rather than moving to the escape position and as such the sub spindle hits the turret.
I have checked the NC code and found that the turret is indeed commanded to G53 Z-400. as per the "Escape" variable in the post processor, but, the turret tool 3 is not called. Basically the reverse of what is happening in the simulation.
So, I have 2 problems.
1, The simulation is not sending the turret to the escape position, or if it is, then the escape position is somehow
set very near or at the home position.
2, The NC code for lower turret is not receiving the tool change to tool 3,( in this case I have selected tool 3 as it will
clear the main chuck when the turret is in the G53Z-400. position)
What am I doing wrong?
