Noob - - - >help
Noob - - - >help
No aplicable
Hello I'm looking for some help regarding feature cam. Sorry in advance for the text I am French and I use Google trad.
I start in CNC machining and I just asked for your help regarding featurecam. I am more or less starting to take it in hand however I have a problem of choice of feature. I can not create a contour of my piece corresponding only to the shape of it without all my rough is completely machined until arriving at the final shape of my piece. What feature / technique do you use? I also have a problem on the creation of my gcodes: from what I understood featurecam puts two codes which conflict on the same line (N7065 G0 G91 G28 Z0 M09) and those on all the generated gcodes. I have to delete G0 so that mach3 can read the g-code but that it affects the machining? thank you in advance
0 Me gusta
Responder
992 Vistas
13 Respuestas
Respuestas (13)
kelbie.ockey
First, I might recommend taking a look at some of our free learning content. This may be of use to you considering you are a new user.
As for your question about the contour (I believe this is the equivalent to a side feature), do you have a .fm file you could attach for better understand the issue? Based purely off of your translated description, I am thinking that the total stock setting may be what you need.
Kelbie Ockey
Sr. Implementation Consultant
0 Me gusta
No aplicable
Actually by adjusting the stock I manage to get what I wanted. :símbolo_del_pulgar_hacia_arriba:
A problem to settle.
It remains for me to settle my concern of g code with the line which puts in conflict 2 codes, if someone knows the cause I would be at the top!
0 Me gusta
ChristopherMarion
@Anonymous
Can you attach the post and fm file so we can look?
The easiet way is to go to:
1.File
2.Share
3.Zip the file to desktop
Attach that file here.  Also, a screen grab of the bad code would help.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
0 Me gusta
No aplicable
Here is the fm file as well as the g-code.
Note that in the machining of the fm file I leave a little material (0.10 mm) so that the parts do not come off and break my cutter.
Is there an "attachment" function included in the program?
0 Me gusta
ChristopherMarion
@Anonymous
Thank you for sending the FM file.  Please send in your post as well (.cnc)
Also, if you can explain where in the NC output the issue is, we maybe able to help you.  Perhaps a screenshot of the error.
Christopher Marion
SolidCAD - Canada
0 Me gusta
No aplicable
Hi there
In your special case, it would still make sense to use the associated one
* .fmp file
ready to provide.
So you get a 100% image of your results.
A screenshot is self-evident and explains exactly across the board.
It is best to insert markings in the screenshot with the graphics program,
So you don't always have to ask.
Your provisioning server is a great thing.
It is just a shame that the download is limited in time, as it is not appropriate if the post is visited by others at a later time when searching for solutions.
Then data is missing to be able to understand.
Upload to the post would be ideal for that.
Yours sincerely
Mathias Beyer
Hallo
In deinem speziellen Fall wäre es noch sinnvoll die dazugehörige
*.fmp Datei
bereit zu stellen.
Somit bekommt man ein 100 % Abbild von deinem Ergebnissen.
Ein Screenshot ist selbstverständlich und erklärt übergreifend genau.
Am Besten im Screenshot mit Grafikprogramm Markierungen einbringen,
Somit muss man nicht immer nachfragen.
Dein Bereitstellungsserver ist eine tolle Sache.
Schade nur das der Download zeitlich begrenzt ist, da es hierfür nicht angebracht ist, wenn zu späteren Zeiten der Post von Anderen bei einer Suche von Lösungen für sich besucht wird.
Dann fehlen Daten um es nach vollziehen zu können.
Upload in den Post wäre optimal dafür.
Mit freundlichen Grüßen
Mathias Beyer
No aplicable
Hello
It would be better to post an extra for each question.
The better overview and to recognize your question at all.
There are a lot of basic questions open to you, which you should work through step by step before your specific questions will come safely.
If I may say so. Sorry
I'll try to address a few things first, but 1001 open questions, I can't answer them all of a sudden
I will try to roughly point this out to you
see screenshots
1.
in short, you should generally adjust your machining configuration first.
This goes on for a long time (weeks, step by step) until you have adapted all of them for you, according to your technology and preference.
Basically everyone works and hires for you.
This saves a lot of routine work, it is worth the effort to save yourself work every day.
Then fine tuning again and again.
2nd
I pre-drilled the holes without roughing and just finished with spiral finishing, especially in the strategy of activating the feature.
3rd
You have contoured with 0 material measurement,
are two options.
Specify material dimensions with 0.5
or
Create profile of contour offset of 0.5 and this profile
or use any profile in the feature as a blank profile
you can specify any blank shape, including volume, etc.
4th
How do you want to dive in?
Where do you want to dive?
5.
what tools and size do you want to use?
Would you like to rough and finish with one or more tools?
Then choose technology
And basic setting in machining configuration, see 1.
6.
If you need training, please organize your support contract through your contract.
7.
Have your * .cnc postprocessor customized at support.
8th.
etc.
1001.
Here you have reached the basics for feature cam.
Please work through it first, step by step
1002.
Here you can start with your own questions
Please open a new post for each, thank you.
Sorry, but in the short time and the many obvious basic points, I can point this out to you first.
If something helped you, please like and mark it as a solution.
Good luck.
And stay healthy.
Sincerely yours
Mathias Beyer
Project:
Please number projects by and not with fm1 etc.
Hallo
Es wäre besser für jede Frage ein extra Post auf zu machen.
Der besseren Übersicht und überhaupt deine Frage zu erkennen.
Bei dir sind sehr viele grundlegende Fragen offen, die du Schritt für Schritt erst abarbeiten solltest bevor deine eigendlichen Fragen sicher kommen werden.
Wenn ich das so mal sagen darf. Sorry
Ich versuche erst mal paar Dinge anzusprechen, aber 1001 offene Fragen, die kann ich dir hier mit einmal nicht beantworten
folgend versuche ich dich darauf grob hin zu weisen
siehe jeweils Screenshots
1.
kurz gesagt, zuerst solltest du im allgemeinen deine Bearbeitungskonfiguration anpassen.
Das geht über eine längere Zeit (Wochen, Schritt für Schritt) bis du die alle für dich angepassgt hast, nach deiner Technologie und Vorliebe.
Grundlegend erst mal alle durch arbeiten und einstellen für dich.
Damit spart man sich Routinearbeiten enorm, die Mühe ist es wert, sich täglich damit Arbeit zu sparen.
Dann immer wieder Feintuning.
2.
die Bohrungen habe ich vorgebohrt ohne Schruppen und nur geschlichtet mit Spiralschlichten, extra in Strategie vom Feature zu aktivieren.
3.
Kontur hast du mit 0 Materialaufmass gemacht,
gibt zwei Möglichkeiten.
Materialaufmass mit 0.5 angeben
oder
Profil von Kontur Offset von 0.5 erstellen und dieses Profil
oder ein beliebiges Profil im Feature als Rohteilprofil verwenden
da kann man beliebige Rohteilformen vorgeben auch Volumen usw.
4.
Wie möchtest du eintauchen?
Wo möchtest du eintauchen?
5.
welche Werkzeuge und Größe möchtest du verwenden?
Möchtest du mit einem oder mehreren Werkzeugen Schruppen und schlichten?
Technologie danach wählen
Und Grundeinstellung in Bearbeitungskonfiguration, siehe 1.
6.
Falls du Schulung brauchst, bitte über dein Vertrag beim Support organisieren.
7.
Dein *.cnc Postprozessor beim Support anpassen lassen.
8.
usw.
1001.
Hier hast die Grundlagen für Featurecam erreicht.
Arbeite die bitte erst mal ab, Schritt für Schritt
1002.
Hier geht es mit deinen eigenlichen Fragen los
Mach dafür bitte jeweils ein neuen Post auf, Danke.
Sorry, aber in der Kürze der Zeit und die vielen offensichlichen grundlegenden Punkte, kann ich dich erst einmal darauf hinweisen.
Falls dir was geholfen hat bitte like und als Lösung markieren.
Viel Erfolg wünsche ich dir.
Und bleib gesund.
Mathias Beyer
Projekt:
Projekte bitte durch nummerieren und nicht mit fm1 usw.
0 Me gusta
No aplicable
Hello
a few more tips on where to look at the start in Fearurecam.
6.
Strategy in the feature
Strategy in basic settings of Featurecam
Well, that should be enough for a while.
I hope I could give you some food for thought.
In the following post from me I have another surprise for you.
Stay tuned!
Like? Solution?
I wish you success
Sincerely yours
Mathias Beyer
Hallo
noch ein paar Hinweise, wo am Start in Fearurecam geachtet werden sollte.
6.
Strategie im Feature
Strategie in Grundeinstellungen von Featurecam
Nun das dürfte erst mal für eine Weile reichen.
Ich hoffe ich konnte dir paar Gedankenanstöße damit geben.
Im folgenden Post von mir habe ich noch eine Überraschung für dich.
Bleib gespannt!
Like? Lösung?
Viel Erfolg
Mathias Beyer
0 Me gusta
No aplicable
Hello
Now for the surprise for you.
I am attaching extensive instructions for Featurecam 2016.
The remaining questions up to point 1001 will be answered here in 2400 pages, suitable for amateurs, advanced and professionals.
I can't do more for you.
Like? Solution?
I wish you success!
Stay healthy!
with friendly greetings from Germany
Mathias Beyer
To the Autodesk team.
Maybe make a request to the development team
for a new up to date guide to Featurecam to the extent and manner as posted here.
Thank you in advance!
Who would like that just like!
Hallo
Nun zu der Überraschung für Dich.
Ich hänge eine umfangreiche Anleitung für Featurecam 2016 an.
Hier werden dir in 2400 Seiten die restlichen Fragen bis Punkt 1001 beantwortet, geeignet für Amateure über Fortgeschrittene bis für Profies.
Mehr kann ich für dich nicht tun.
Like? Lösung?
Viel Erfolg!
Bleib gesund!
Mit freundlichen Grüßen aus Deutschland
Mathias Beyer
An das Autodesk Team.
Vielleicht mal an das Entwickler Team eine Anforderung machen
für eine neue aktuelle Anleitung für Featurecam in diesem Umfang und Art und Weise, wie diese hier gepostete.
Danke im Voraus!
Wer das auch möchte einfach Like!
0 Me gusta
No aplicable
Maybe this link will help you too
download offline help
https://knowledge.autodesk.com/de/support/featurecam/downloads/caas/downloads/downloads/DEU/content/...
Vielleicht hilft dir auch dieser Link
download Offlinehilfe
Mathias Beyer
0 Me gusta
No aplicable
Do you have your offline help in your language
dowload and installed, then
Activate the offline help in your language in the settings
see the screenshot
In Featurecam, the offline help is then displayed in your language when the help is called.
This is also a useful setting at the start of Featurecam
Like? Solution?
I wish you success
Sincerely yours
Mathias Beyer
Hast du deine Offline Hilfe in deiner Sprache
dowload und installiert, dann
aktive in den Einstellung die Offline Hilfe in deiner Sprache
siehe Screenshot
In Featurecam wird dann beim Aufruf der Hilfe die Offline Hilfe in deiner Sprache angezeigt.
Dies ist am Start von Featurecam auch eine sinnvolle Einstellung
Like? Lösung?
Viel Erfolg
Mathias Beyer
0 Me gusta
No aplicable
Thank you for your help after a few hours of practice I start to see clearly.
However, I still have my g-code problem, I will put a screenshot with the line where two codes conflict.
If I remove G0 from the mach3 line happens to read my g-codes to me but I am not sure what this may have on my milling.
Thank you
bhorstTGM48
If you attach your postprocessor that is a pretty easy fix.
