Non-cutting moves
grosucsm
Non-cutting moves
grosucsm
Please help me ! I am making a pocket, predrilled with a drill of 50 mm diameter, first rough with porcupine miller diameter 40, rest of the material on second rought with solid carbide miller of 16 mm diameter and I have non-cutting moves with feed instead of rapid. How can I make non-cutting moves with rapid ?
0 Me gusta
Responder
Soluciones aceptadas (1)
703 Vistas
13 Respuestas
Respuestas (13)
abhishek.juvekar
Hi @grosucsm,
Thanks for raising your query on Autodesk Forum.
Is it possible for you to upload the fm file to investigate in detail?
Thank You.
Abhishek
0 Me gusta
grosucsm
Thank you for your fast answer.
0 Me gusta
abhishek.juvekar
Hi @grosucsm,
Thanks for supplying the fm file.
In your fm file, you have created a pocket feature using Spiral with pre-drill operation. When multi-roughing with a pre-drilling operation selected, the second roughing operation or rest roughing operation uses the pre-drill location as its plunge point which is not sensible at all. This is why you are seeing those non-cutting moves from center.
This has been reported to the development team already and it is being considered for possible cause and solution.I have added this forum thread in the same.
As a work around, you can either change the strategy to Vortex but you will lose the ability to set pre-drill location.
Or you can create an independent drilling operation and uncheck pre-drilling from existing pocket feature. Then use the location of independent drilling operation as a plunge point.
Hope this helps. Let me know if you have any questions.
Thank You.
Abhishek
grosucsm
I have made the pre-drill operation in a separate operation, but I still have non-cutting moves, the problem is not the non-cutting moves from the plunge point to first cutting area, the problem is the non-cutting moves when the D16 miller moves from an area to another area (rest roughing).
0 Me gusta
grosucsm
I can not use Vortex because I can not select the plunge point for the D40 miller, the feature is selecting it in a position where I have a groove in the part and breaks the D50 drill.
0 Me gusta
abhishek.juvekar
Ahh! Ok. You have set Minimize retract in strategy page. Uncheck it to resolve the issue.
minimize_tool_retract.pngThank You
Abhishek
grosucsm
I have unchecked "Minimize tool retract" it look Ok, but now it makes the rapid moves above the part. How can I make them to be at the bottom of the part ?
0 Me gusta
abhishek.juvekar
I have attached the fm file. Let me know how it goes. It will retract only when it will travel from corner to corner.
Thank You.
Abhishek
grosucsm
This is how I did it but, I want to go with rapid between the corners without the retraction of the tool above the part.. is there a way to make it ?
0 Me gusta
abhishek.juvekar
Solución aceptada
As far as I know, then only one option remains that is creating a toolpath feature and edit those moves to be Rapid. You will have to turn on Minimize Tool Retract and create a toolpath feature of rough pass2.
Refer a video
Abhishek
grosucsm
Thank you !! It's Ok, I can make what toolpath I need with rapid, this solves me also other issue.
0 Me gusta
No aplicable
Hello
Your video is very helpful, thanks.
Anyway, your answers are always very instructive, I appreciate you,
I myself have always not understood why the rapid traverse is not used and works for this reason always with withdrawal of the tool, because this effort is too large.
As a continuation would be interesting in the video to see how you put this into the program?
Do you delete the corners in the complete list of operations and simply insert the toolpath for it?
Or what is the way to the complete result?
If you have time, thank you in advance!
Yours sincerely
Mathias Beyer
Hallo
Dein Video ist sehr hilfreich, danke.
Überhaupt sind deine Antworten immer sehr lehrreich, ich weis dich zu schätzen,
Ich habe selber immer nicht verstanden warum der Eilgang nicht verwendet wird und arbeitet aus diesem Grund immer mit Rückzug des Werkzeuges, da mir dieser Aufwand zu groß ist.
Als Weiterführung wäre interessant im Video zu sehen wie du das ins Programm einfügst?
Löschst du dann in der kompletten Operationsliste die Ecken und fügst einfach den Werkzeugweg dafür ein?
Oder was ist der Weg zu dem kompletten Ergebnis?
Wenn du Zeit dazu findest, Danke im voraus!
Mit freundlichen Grüßen
Mathias Beyer
0 Me gusta
grosucsm
After I did the cutting operations, I have used the toolpath operation, then I have unchecked the operation from the Setup 1 (yellow).
0 Me gusta
