No Model Error! PartMaker Swiss
tstudley
tstudley
Haven't  used partmaker for a while and now when I go back to existing programs they wont run through the simulation, it seems the toolpaths are missing from the surfacing ops. I also can not generate new toolpaths in Surface Group Parameters?
Any ideas?
ChrisDPCnc
yep I had this just the other day too.
PartMaker get all confused about which AMDEU version it should be using.
Close all your AD programs first.
Go to ALL APPS find the folder for Autodesk Manufacturing Data Exchange Utility for the PartMaker version you are using and hit the COM Register button.
This should sort it out.
I guess you have some other AD products from different years on your PC? If so you may need to do this often.
