Anuncios
Need 4th axis program off of a solid, only have standard autodesk featurecam
No aplicable
0 Me gusta
Responder
332 Vistas
2 Respuestas
Respuestas (2)
kelbie.ockey
You're probably not likely to get anyone to completely program a part for you on the forums for liability and personal bandwidth reasons.
With that in mind, there are a couple of options I would recommend. The first would be to check out our Partner Network, as they will do 'programming for hire' projects such as this. Just as a heads up, if you get in contact with one of them, they are going to need more information such as the machine you are programming for, tooling, etc.
The other thing you honestly might consider is programming this one-off part in Fusion 360. It can be downloaded for free, and you will be able to program a 4th axis part.
Kelbie Ockey
Sr. Implementation Consultant
No aplicable
hi,
you can do 4th axis with FCAM Standard
for importing you solid you just have to  save this one as a .SAT file and then you will be able to import it in FCAM
0 Me gusta
