No aplicable
07-31-2018
11:24 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
In a turn program, when i give depth of hole 92 mm. The NC output gives me 97 mm. Same goes with the ID boring when it should be 36, the NC output is 37. And canned cycle of ID bore tell me to give start point. After providing start point still the canned cycle of bore is wrong and either way it is. And also feed rate is on higher side for material i have selected, i have to reduce it to 50% to match proper feed rate, material is steel 10xx. And RPM of center drill is much higher, other operations have proper RPM. I am attaching all the files. Thank you.
https://ibb.co/dA03ve
https://ibb.co/idWAae
https://ibb.co/gHoOve
https://ibb.co/ffa3ve
https://ibb.co/nc1MgK
¡Resuelto! Ir a solución.
